why very hard to find evo1,2 piston..haih..
not rich as u la yong..weh..my fren order apamacam?
inspect properly when buying 2nd hand evo piston.... most popular prob is the ring land crack... or the piston already longgar...
mmc piston always lame bro,if toyata one will stronger abit
anyone selll vr4 flywheel?
now day...all the after market piston not that expensive compare those days,
so why not opted the forge piston...sure u wont regret...do it rite at the first place.
its very hard to find vr4 flywheels nowaday and to pricey, above RM400 .. I end up ordering fidanza flywheel from oversea![]()
That's right. Haih... too bad forgies are still expensive for GSRs
Kaye nampak..
very hard to find, have to go round 1 kl and the price:stupid:
Hi bros,
I just acquired a Satria with 4g67 engine block and pistons + evo2 4g63 head, ecu and MAF + td05 18G with banana manifold.
I would like to know from experience, how much boost can the 67 block and pistons withstand? I checked my compression is about 170-175psi across the range
Thanks in advance guys :)
6G67 block + EVO 2 pistons + EVO 2 head with stock head gasket should give U Compression Ratio 8.5. Which is similar to EVO 2.
Bro... don;t ask how much boost ur engine can take. consider how much hp ur engine can withstand.
Have a targetted HP and begin modding from there. See what u should do.
Or u just gonna boost as high as ur engine can take and see wad HP figure it can produce. Then live along with it... If management is good, tunning is good, other supportive modification is also good, 2 bar no problem.
If stock ECU to manage the air fuel, 1.5 bar and ur engine gone....
Get it mou..?
