Kota Kinabalu....
ohhh u tat person using green cyborg satria ahh?hahaha...
Kota Kinabalu....
yaya..lets tt went bck this coming raya...haha![]()
EG6 has a better advantage.
1. you have 20G, your boost will come too late.
2. You are running 1.5bar. Is not enough to compensate the different in weight.
3. Your intercooler probably going to get heat soak after 2nd gears with Malaysia weather
You will have better change with bigger downpipe, larger exhaust, Big 16G turbo, piggy ECU, and 2.2bar of boost.
Good luck. Cheers
Good luck. Cheers
big 16g is simply just blowing hot air at 2.2 bar.. his 20g setup is much much better than 16g...
as i said before, the key is traction...
Please.... you dont' know what you are talking.bro .... 2.2 in the compressor map shows pressure ratio... not exactly the turbo spooling 2.2bar... dont get mixed up pressure ratio . we cant take the absolute pressure of 1bar or 14.7 psi as the P2....your sea level elevation, air filter restriction, piping loss all can deduct your P2 to quite an amount. so at 2.2pressure ratio normally it will be far less than the actual 2.2 bar you mentioned. and at that pressure, take a look at the airflow rate it is giving as well as hp is very much directly related to airflow that the engine is being feed
at 2.2bar, is just about the outer edge of center island. Is still at good compressor efficeincy.
20G has too much turbo lag & too narrow powerband for his application.
For a highly modified 2.0L 4G63 running 20G, boost won't come before 5000rpm. By that time, EG6 will be far away.
Is not always the bigger, the better.
huh, u sure bro , Td05 20g + 05h turbine wheel spools full boost before 4k , td05 20g + 06sl2 wheel which happens to be FP Sleeper 16g spools full boost far before 4k , same td05 20g is called the bastard 20g by slowboy racing full boost far before 4k, td06 20gSL2 is also a good choice with 7cm turbine housing for faster boost also full boosts before 4k , of cos if we step a lil higher , FP Green also known as 50trim garrett/pte scm series both makes full boost around 4-4.5krpm 450hp capable , but to be suprised the H1C and HX35 beats alll this snails , a HX35 in a bullseye housing makes 20psi by 3500rpm and its capable of making 550hp :P , S200 borg warner also makes very fast spool up and it is in the 500hp+ range , the days of extended tip's and billet compressor wheels are coming up , :P i dnt know y , i jst dnt like the garrett ballbearings :P too expensive and to repair it is sometimes imposible , all this applies for 2.0 4G63T , for a stock engine and fast spool up, i will of cos vote for the td06-20gSL2 :P , all the turbo's i mentioned above are all plug n play to stock 4g63 manifold , no banana :P
I owned the book for more than 4 years. I am glad you are still learningi recommend u to read "Maximum Boost Book by Corky Bell" , im also still learning
Anyone know where can I get the clips from?? I search a few spare part shop in PJ area, they don't have it...
