APEXi DECS Tachometer
KAY 3333
kedah&penang
any one know this meteR??? how many pressure and temp sensor can fix on it???
i try to find it on internet but return 0!!!
is it hard to find the sensor??
Err. the Decs Tachometer from Apexi is just a Rev Meter lah..
Oil pressure and other temp sensor, you can opt for gauge holders that are either made from fibre/carbon/plastic, or you can use Defi's single DIN meter which has fuel pressure, water temp and oil temp.
Opps...
I see you are talking about the new model..
never knew about integrated sensors, but I think apexi sells them. try email them and ask.
http://www.apexi-usa.com/product_electronics_detail.asp?id=219&pageNum=1
if they expect you to use 3rd party sensors, then this is the site for it.
http://www.racetechdirect.com/
i alrady go to the two website but it din stated can fix how many sensor to the tacho
If you really like the item, go to any shop in Sunway and ask to look at the manual.
Usually they allow you to look it over before buying.
But I can guess around 3, which is the usual suspects, water temp, fuel pres, oil press.
