suspension rubber
qkfxxxx
29
currently my car i feel is too low so i ask my mechanic to rise it abit. but mine is non adjustable so he asked me to put some rubber part. what is this rubber that supposedly will rise the suspension abit? is it expensive?
mag9556
2,770
43
1,648
Actually it is called as rubber bush that Taxi always use it..
very cheap only...
Check at the search forum abt this.. there is a treath abt this...
Good Luck...
qkfxxxx
29
owh...ok thanks..btw if i add on this, the car wouldnt be as bumpy also right?
dennisdreams
333
21
Actually it works this way, the rubber is sited on the base/top of your spring which it rest on the absorber base/mounting. It's work is lift your car ride a bit higher (normally 0.5~1 inch) For your rides is bumpy, that would means that the gap between your absorber's "shock bump(the rubber thingy which sit around your absorber's shaft)" and your absorber is less than 1 inch. To get comfortable ride, it's strongly recommended that the space between them to be keep over 1.5 inchs.
cik_yat
384
Miami
wandianagarageinc.blogspot.com
i use the 3inch rubber for my rear wheel combine with standard spring and kyb gas abs.. so far not too bumpy.. maybe coz got ARB.. but cornering not so good..
dennisdreams
333
21
3"~ sound your car is riding a bit higher than it should be. i think your tire had about to lift off the ground already.
cik_yat
384
Miami
sound like dat.. but its only bush height... the gap only rise 1-1.5 inch.. coz standard bush already 1 inch...
qkfxxxx
29
hmmm dont really understand...u r not talking about rubber hose inserted into the spring are u?
Similar threads   Forum
  Similar Threads
