Hi Khoyos,
Thanks for the advice. =)
Previously was 1.2bar with no overboosting sign. Means no problem adi (mayb...) So. 0.8 bar should be no problem right?
em.. I will try it out.
Hi Ken,
Haha, I don't wish to be monster. smooth drive, smooth acceleration will do. Especially bypassing the front car.
Yeah, how is your fuel consumption? Mine is very very bad i presume. Off boost with vacuum driving only will cost me RM50 = 120km only. It was running 42psi running engine fuel pressure. :confused_smile:
After searching all over, i decided to do a test. I follow the specification of the stock standard engine and start troubleshooting. Hope i am doing the right thing.
Now running on 35psi engine running. :X-:
Got this from
mazda ford enthusiast - malaysia: Forum
Fuel Delivery/Turbocharger System
Description Specification
Fuel Pump Outlet Pressure (Maximum Output, Key ON, Engine Off)
1.3L More than 340 kPa (50 psi)
1.6L 441-588 kPa (64-85 psi)
1.8L 44 1-588 kPa (64-85 psi)
2.0L 44 1-630 kPa (64-92 psi)
2.5L 500-630 kPa (72-92 psi)
Fuel Pump Pressure (Fuel Pump Terminal Grounded, Key ON, Engine Off)
1.3L 265-320 kPa (38-46 psi)
1.6L 255-289 kPa (37-42 psi)
1.8L 265-3 14 kPa (38-46 psi)
2.0L 255-320 kPa (37-46 psi)
2.5L 270-3 10 kPa (39-45 psi)
Fuel Pump Pressure (Key ON, Engine Running, Pressure Regulator Vacuum
Hose Connected)
1.3L 210-260 kPa (30-38 psi)
1.6L 189-231 kPa (27-34 psi)
1.8L 216-264 kPa (31-38 psi)
2.0L 207-262 kPa (30-38 psi)
2.5L 207-248 kPa (30-36 psi )
Hose Disconnected)
1.6L 249-297 kPa (36-43 psi)
1.8L 275-336 kPa (40-49 psi)
2.0L 269-310 kPa (39-45 psi)
2.5L 269-310 kPa (39-45 psi)
Fuel Pump Volume 1.3L, 1.6L, 1.8L, 2.0L, 2.5L =
(5.5 ounces)/10 seconds
Fuel Pump Check Valve Leakage =
2 psi maximum in 3 minutes
Fuel lniector Leakage =
1 drop maximum per 2 minutes
Fuel Injector Resistance =
12-16 ohms
Fuel Pressure Regulator Pressure Leakdown =
34 kPa (5 psi) maximum in 60 seconds
Fuel Pressure Regulator Vacuum Leakage at Valve Seat =
10 in-Hg maximum 10 seconds starting with 20 in-Hg vacuum
SPECIFICATIONS - 1.6L TURBO
Boost Pressure. Maximum 56 kPa (8.1 ~ s i )
Turbo Wastegate - AirPressure to Open 56 kPa (8.1 psi)
http://w.techcapri.com
Copyright (c) 1993, Ford Motor Company 1994
Powertrain Control/Emissions Diagnosis A U9~3
