A streetable 300whp NA VTEC
hattech-v,
nabeh u...in d end sure u wana kenakan me heh?dey,4 once,lets not hijack ppl's thread......coz its been a LONG LONG time since such interesting thread has surfaced......
n yeah,i still wana know d location of dis AvantGarde garage?
Actually guys, I'm not able to reveal too much about the build as it is not fair for the many parties involved..especially for the owner :regular_smile: !! Alot of time, effort and $$$ has been invested to obtain the info and data that we have in our hands today. But I will reveal as much as I think is fair for all. Thanks B :angel_smile: !
K24 short block - Stock Honda K24 crank with stock 99mm stroke.
Forged pistons (AvantGarde spec) - Bore size, compression and valve relief depth was made to AvantGarde spec. The exact spec of the piston would be the trade secreat part :fear: . Will post pics later though so u can check it out yourself.
Forged con-rods - I beams with XXX length :fear:
ACL Race series engine and con rod bearings
K20A oil pump
K20A water pump
Custom Crower Cams (AvantGarde spec) - Cams were custom build to AvantGarde own valve lift and duration spec. "Wish I had my own cam making machine"
Crower Valve springs
Ferrea stainless steel valves
A custom ported cylinder head (port and polished by AvantGarde) - Because the K24 is such a long stroke engine, the stock K20 heads will choke the engine at higher RPMs.From the bore, stroke and static compression ratio of an engine, one can calculate an estimated figure on how much the engine can ingest. With that estimated figure we start working on the head. From our own experience porting heads, we roughly know how much to cut to achive the flow figures we're aiming for.Since we're using oversize valves, the valve seats had to be replaced and the angles recut to again our own spec :fear: .After which we cc all the ports n combustion chamber to make sure eveything is equal.Then the head is send off to be flow benched. From then on it's just touching up here n there to make sure all the ports flow as equally as possible.
Jenvey individual throttle body (AvantGarde spec) - Funnel length and size as well as the throttle body size would be the secret part :fear: !!
Hytech custom build race header for K24 - We basically gave them our entire engine specs; bore size, stroke, compression ratio, cam spec and application and they just sorted everything out for us. RM6xxx and 3 months later...:rock:
Hondata K-Pro
Exedy Hyper Single Clutch set (the only jap item!!)
ARP bolts and head studs
Cometic head gasket
AEM aluminium pulleys
RC Engineering injectors - :fear:
Ok guys I hope I've answered most of your questions already. Will post pictures later tonight so stay tuned. Again, for those of you who are genuinely interested in our build, please come by and have a look for yourself. You won't be dissapointed :regular_smile: !!
Game,,,what is the k24 bore/stroke size,,,? and what is the target RPM ?
Feed us more technical spec pls,,,,k20 makes me hungry lah.:shades_smile:
The project belongs to many entities. I think thats the most they can provide. If you need more info and specs, as mentioned before, please contact Avantgarde or Driven driectly.
Reposting details of contacts and dyno:
Avantgarde: Eric 0173341223, James 0192828640
Driven : http://www.driven.com.sg/Home_Performance.asp
Dyno chart
http://new.photos.yahoo.com/nismo502/photo/294928804312069568/0
http://new.photos.yahoo.com/nismo502/photo/294928804312069569/1
aisey... cannot wait for the dyno chart laa...
if cannot post here akuma oso can claim his b16 got 388atw hp....
Aisey.. don't tipu people lah mie.. Everyone knows akuma got 888 at the wheels...
The toyo R888s, that is..
Wakakaka..
Tok kok conversation session ends..
So.. Game, I'm assuming you got the stage 2 driveshafts from driveshaft shop? El-expensivo! (O_o)
If not.. damn.. I didn't know the stock K units can take that kind of power... cool...
So why do you reveal all the parts here ?? parts is only a tip of the iceberg,,.
To clear the perception that not only americans can build 300whp na vtec? Then again, a lot would claim it is easy, if it is, it would be my apologies for my ignorance.
None is denied further information if they are sincere enough and would enquire directly with the relevant parties, they can even view it :)
As explained many times, it is just not convienient to put it online as there are many many parties involved.
Congrats,,,i saw the chart and it went 300 on 8100rpm. Do you clock a 1/4 timing ?? Mind if i guess is it on an EP,,, did high 13s...?
erm.....if so difficult, involved many parties etc etc then better dun revealed anything!!!!!
most of forummer here wanna learn and learn and learn theoritically, practically and facts!!!! everybody here mod their car and revelaed the detail specs for each of everybody benefit, not to be rude, proud or watsoever, they just wanna share!!!!
just my RM0.25
can i comment on sumthg?especially abt ur torque curve.ur running a K24 n w all d goodies,arent u dissapointed w how d torque curve turned out 2 b?if u ask me,d setting/tuning cud probable b improved on.....
lastly,u mentioned dat dis beast is made in m'sia...so y d need 2 dyno in S'pore?is d Dynapack more accurate or what?if possible,i'd like 2 c dis car being dynoed sumwhr else n reproduce consistent results..dats d right way 2 back up d power&torque claim,right?.....
n heck,congrats on d build..its impressive no matter wat.....
Wait.. how many engines are there? One says that it's being built, one says that's it's done already.
But since the 300hp mark has been touched.. I congratulate the parties involved...
But it is 300whp... right?
avantasia,
r u hinting sumthg @ me?coz i dun remember me revealing anythg abt y car or set up...ooo..so now u wanna marah me lar?damn....i just cant keep my 388atw secret a secret anymore is it?n my 888atw secret has been revealed by shiro!hahahaha.
(damn,here v go,hijacking ppl's thread,AGAIN!)
yeah true also,,,which one is which ??
just my RM0.25
my rm 0.10 cents then.
dude, the tel numbers are there, the website is there. You or anyone has not been denied any facts. In fact, you are welcome to enquire! But it is certaintly not correct to put an outright specs online since it is something that someone else paid for without permission.
Nismo,,,if you can paste the ignition map here,,ill be happy for a week,,,and ill ask you no more question.
1st one is 300whp done, dynoed and completed. Maybe some finetuning to smoothen out as what akuma has mentioned. 2nd one is being built now as we speak :) Thats why i have been stressing in my previous posting, contact relevant parties if you want to see how it can be done again.
Whats the 1/4 timing then ?
hmm...this is internet hor, i can claim anything right? :) Honestly, it is not tested. But the plans for the car is for it to be a timeattack vehicle. They are trying to sort out handling now.
