Welcome to Cefiro Club Malaysia
317
3,018
haha sad lo what causes a wrap?
anyway how much to replace wor?
stock ones vs peformance ones :D
ongteckweng
5,000 RPM
5,806
55
oh yeah...sorry...its warp...not wrap...hehehehe
usually is cause by water!!! ok..when u r driving, the rotor will heat up. n bcoz of our car is heavy, they tend to heat up very quicky if u r goin down hill or long distance drive. sometimes when they r not cool down n u wash ur car, they will warp. also happen if u go thru floods...
stock will do coz even if u get performance rotors, ur normal pads will not last long...:biggrin:
0123
317
3,018
hmm i changed the stock pads to ferodo adi :D
so can anot leh?
actualyl what diff does it make if i get peformance rotors?
:D
ongteckweng
5,000 RPM
5,806
55
so can anot leh?
:D
i think the main advantage of performance rotors r they r able to withstand high temperature without failin...but expensive. n dont think they have it for all cars.
just like racing pads, even if u trash them, they will work. but if normal pads, the temp is lower than racing pads. so they r easily overheat if u trash them n they will fail to perform normally
0123
317
3,018
hmm okay
i think i might try the peformance rotors if they aren't tooo exp lol :D
thanks ong for the info :D keke
so hows the titan going?
weikee
924
15
disc warp are due to many factor, and personally have encounter few reason for the disc warp,
01) bad quality brake pad.. i used one so called expensive pad, and it warp 2 set of my disc, than later decide to change the pad, and skim the disc... and working fine.
02) due to heat dissipation very bad.. used to drive a sentra B13 with upgrade disc and caliper. with the standard rims, i always have my disc warp, and change every 6 months.. later change to bigger rims no problem.
03) heated disc after usage and cool by water.. usually happen when you send your car to wash.. <yet to try, but its common for normal users>
RM 350 per disc, if can change to 4 pot nissan brake lah :D
ongteckweng
5,000 RPM
5,806
55
agree with weikee...now i learned more...
anyway, changin to 4-pot might not be a good idea as we have discussed b4 during our last TT.
our brake pump is not big enough n they might have hard time with d 4pot. if u wanna change to 4pot, consider the brake pump n brake line as well
weikee
924
15
Hi Ong,
for the brake pump, can always used the R33, or any nissan master pump with 1" size. Think the minimal is 15/16" but you can check it out in the chop shop they have lots of master pump for nissan with various size stamp on the brake pump. just take one that are higher than current one and the hose run the same way.
Used to upgrade my sentra with the twin pot and master pump... brake today stop yesterday :)
now with fatty, brake today stop tomolo... need to upgrade soon
0123
317
3,018
aiks i also duno what to do what weikee's idea sounds good haha.
but how much you recon it will cost to change them O.o" disc & 4 pot caliper
and also the pump n line??
dream.tent
976
24
3,018
www.cardomain.com
But our Feilo with Electronic Brake Assisted, how to go about? can change the master pump?
If so, maybe it's a good idea to just folklift the master pump and 4 pot brakes. brake lines not too expensive! good to have them too!
defcon1
775
2
i would first explore changing the master pump. My Celica before had only twin pot calipers and weighed 1.54 MT (1.55 with me in it)...but managed to stop much faster than the feilo.
Let me ask Lee and see what we can work out... :smile:
Also, you might consider steel braided hose and dot 5 or 6 brake fluid as a fast and effective upgrade. You will find that your braking performance improves by at least 10% - 15%, which is a lot... :smile:
weikee
924
15
hi Defcon,
brake steel braided hose actually don't improve the braking performance, but will reduce the spongy feel. I used to have one set in my old sentra.. and this things don't last longer than the OEM hose.. the dam hose leak, and i lost brake.. wramp into a few months old 5 series.. gosh... that was bad... lucky i was traveling slow and damage are not too bad. So when used steel braided.. please change every 2 to 3 years.
For 4 pots, you can try the silvia S14, or S15 its smaller compare to the skyline. Think someone in this forum selling it around 400 +-. For skyline 4 pots, my last purchase nearly 2 years ago are 500 for complete front and back, front its normally rm 300 ++. Now maybe 400+-
If not mistaken the A33 EBD control by the ABS pump just like the N16, and P11 SR20ve. My friend upgraded the P11 sr20ve 4 pots and n16 (to twin pot, rear cefiro) its working and actually its perform better cause its distributed very well for the N16.
I am planing to put in 4 pots once i full done out my engine, and change to 16 or 17" rims
defcon1
775
2
Braking is actually a function of pressure and time. "Reducing the spongy feel" by using steel braided brakes lines and using higher dot rating fluid basically means reducing the time taken for the brake system to reach maximum braking pressure. This happens because :
a) The rubber/teflon hose inside the steel braid has only the confined space inside the steel braid to expand when brakes are applied.
b) Higher dot rating hydraulic fluid has a lower compression capacity, again reducing the time taken for max pressure to be achieved.
Whether they last longer or not, depends on the quality of the brake line installed. Technically, these are supposed to be high pressure hydraulic lines, and if properly made, will generally last years. My Goodridge set lasted me 5 years until I was forced to get rid of the car in Sg without a leak. The ones under my car now, are locally made, but have yet to start leaking.
You are right that 4-pot calipers should work better by DISTRIBUTING the force over a larger surface area. BUT, the amount of force remains the same, simply distributed over a larger area. The question is...is it really necessary? A combination of good response time, plus good brake pads should suffice for most people here.
A direct way of increasing braking efficiency without major surgery is to increase the clamping pressure of the existing brake calipers. But this has to be done carefully, or you'll actually start to leak... :smile:
And I haven't even started on the material and design of the disk yet... :smile:
weikee
924
15
my 2cents, braking performance are base on few factor, clamping force, clamping area, material, distance between caliper to the center point of the disk. Any of this increase will give better braking result.
thats the brand i was using, and it give way after 3 years.. well maybe i clock to high mileage already..not too sure about the improvement of normal to steel hose, never really feel and major drop in the braking power when i change it back to normal hose.
the 4 pots in the a33 should do better comparing the a32. it got ebd and should be able to distribute the force better. just like my friend ex-20ve we used to drive.
Actually i am a brake fanatic and spend quite a bit of money on brake for my previous sentra. from normal vacuum pump to big pump, to larger master pump and to caliper & disc from single to 4 pots.. you name it i change it.. even CNC fabricated a mount to make a 4 pots and 2 pots for bigger disc..and end of the day, the hose that kill my braking power..sigh
Oh, btw, do change brake oil regular, cause contaminated oil will kill the ABS pump fast. I flush every 12+- months.
dream.tent
976
24
3,018
www.cardomain.com
So far i don't practice change brake fluids. But when it gets dirty and no longer looks clear, i'll have them flushed. Using Dot 4 all the while. Even with my Feilo now. Didn't see Dot 5/6 around actually! need to special order?
A Post Every 5 Mins
This is what DIY detailer do when detail car engine, just clean the engine.....:biggrin:
This was done a while back but did not post, here are some write up and pictures.
Use DG431 Truck and Equipment wash
Just spray water to engine to wet it, spray DG431 on affected area, brush with paint brush to loosen the dirt, then hose off...
Rocker cover....Before...
