i think ur disc wrapped....have to change...skim also no use...
there r no warranty for disc rotors...its a wear n tear thingy...
hmm i changed the stock pads to ferodo adi :Doh yeah...sorry...its warp...not wrap...hehehehe
usually is cause by water!!! ok..when u r driving, the rotor will heat up. n bcoz of our car is heavy, they tend to heat up very quicky if u r goin down hill or long distance drive. sometimes when they r not cool down n u wash ur car, they will warp. also happen if u go thru floods...
stock will do coz even if u get performance rotors, ur normal pads will not last long...
i think the main advantage of performance rotors r they r able to withstand high temperature without failin...but expensive. n dont think they have it for all cars.hmm i changed the stock pads to ferodo adi :D
so can anot leh?
actualyl what diff does it make if i get peformance rotors?
:D
just like racing pads, even if u trash them, they will work. but if normal pads, the temp is lower than racing pads. so they r easily overheat if u trash them n they will fail to perform normally
A33 Rotor original @ RM 350 each.
Similar threads | |
