if you notice the engines that have knock sensors have higher compression ratios like the dohc vtecs. obviously for the detonation/pinging that usually occurs with the higher compressions.
as for as i know for sohc vtec, only the latter 1.6 model comes with the knock board. the rest doesnt come with it.
tuned chips disable knock sensor for extreme high-rev performance.
so if the factory engine and ecu does not come with knock facilities, dont be alarm unless your mechanic wants to make money out of you. hehe.
jingut_04 said:sorry to ask,how look the knock sensor board?i'm using SOHC Vtec(local model)is it mean my ECU have no knock sensor board(even last time facing knock sensor error) & my mechanic ask to change.
p/s:mie,kalo ada gambaq,kasi post tgk
