LimauKanker
- Joined
- Aug 27, 2018
- Messages
- 110
- Points
- 28
toyota sensors and parts shouldn't be more fragile than mitsubishi i guess. the iscv/tps issue small thing la.1JZ is an old engine and the throttle position sensor (TPS) has been known to act up causing idling issues. ISCV aka idle speed control valve sometimes known as the IACV @ idle air control valve controls the idling of the engine and should be changed just for good measure. Once everything works, runs good and has no issues - then only mod. One of the biggest mods hybrid E36/46 owners do is the intake manifold. The Greddy one or whatever is bigger and smoother allowing for more air and blah blah blah. Then consider a good aftermarket ECU like Links Extreme and convert your car to DBW. Then single turbo and top feed injectors. Then the differential or final drive. You're not going manual right?
DBW very good remedy, but a little bit expensive, throttle body + Pedal also good 4-6k depends on what size and specs you're going for. not to mention to modify the bracket for it to fit. can introduce auto rev match, can eliminate medieval tech like iscv and all.
janji the longshaft not welded dead. haha
Have replaced complete float unit (brand new from Wing Hin) still...
