Want 2 modified my dad's toyota unser 1.8gli
alcyon
800
153
543
All you wanted to know about the 1g engine. All are 1988cc, 6 cyl in line.
It had many variants, the first was 12Valve (2 Valves per cyl), SOHC, 1G-E
the 24 valve DOHC is 1G-GE (U)
24 Valve DOHC with turbo 1G GTE (U)
24 Valve DOHC with supercharger 1G GZE (U)
the 1G is engine series, and additional codes after that..
E - Electronic fuel injection aka EFI
G - DOHC 4 valves per cylinder
T- Turbo / Twin Turbos
Z - Supercharger.
U- catalytic converter
These codes apply to other toyota engines too.
https://jalopnik.com/toyotas-first-twin-turbo-straight-six-is-stranger-than-1824260905
Reactions: Izso
7,514
dammm... nice sleeper build...
RENESIS VIII
7,063
950
Ipoh
Like this I think I can go modify my Avanza at home already since also RWD based layout.
i just had my battery relocated to the trunk and i could not be sure whether this had caused me electrical unstablity because im noticing small bouncing rpm when signal light is on during idle, the vacuum meter dims when headlight and signal is switched on
my car is not super audio equipped, only brighter PIAA headlamp, and the meter. i have 2 stabilizers and problem still persists
i just talked to a friend who told me i need to get a grounding wire from alternator all the way to...
