Air cond compressor clutch not engaging properly
Yeah there is a clutch kit available, but it doesn't sound cheap, very near to a reconditioned aircond compressor. AFAIK a lot of shops they only carry reconditioned, new units are replacement from China.
I kind of think of that too. For now it will still ice cold when its operating normally. Let's hope it doesn't occur too many times.
Thanks,
Ken[/QUOTE
It will occur if u are stuck in stop and go traffic.
if highway cuising it wont happen
plus it will only happen after u have driven for certain distance.it wont haopen from cold.
sweelt
Nov 6, 2016
2,306
248
Fan speed or abnormal radiator temp but not cause engine problem. Checked OK?
Radiator water low also a problem, since it won't transmit correct temp too.
Mitevo7
1,456
179
Thanks,
Ken[/QUOTE
Not really, everyday i trapped in traffic jamme and my AC works normally. Like i said its very random and for more than 10 days it never occurs even i am driving during hot weather and traffic jamme.
Thanks,
Ken
Mitevo7
1,456
179
I just serviced my radiator and new coolant and it starts showing after that. Thermostat and waterpump was changed during the repairs too. What do have in mind after i told you this?
Thanks,
Ken
sweelt
Nov 6, 2016
2,306
248
Since almost all u change. Need expert dy.
At least u know it happened after the replacement as stated.
Years ago i have this symptom too. Old sentra Aircond intermittent hot/cold. Until one day whole engine overheat. Block crack. End up all my mistake and learned from it.
Not mean to scare you. Just share my experience.
i think you have different situation.
Mitevo7
1,456
179
I am pretty sure my engine compartments are well protected, no oil leaks (gasket changed), CVTF is serviced earlier than usual mileage and fitted with Hayden CVT cooler (no more whining noise when using sports mode). On long drive everything is just nice.
What causes your engine crack ??
Thanks,
Ken
sweelt
Nov 6, 2016
2,306
248
overheat bro, can see hairline crack. No mods, just my ignorance make it happen. :banghead:
Not a know car guy during that time, 10yrs ago story.
Mitevo7
1,456
179
Oh ok , it was fixed up after that i assumed? I think you may had a B14 Sentra, used to own a N16 before. Great car for commuting but not for driving fast.
Thanks,
Ken
Thanks,
Ken
Compressor still in good condition might as well repair. Recon quality some times questionable also.....lol
Mitevo7
1,456
179
Saved me tons of trouble last Friday, the compressor finally condemned on me. Here's what i replaced to get back my cold air:
1.) Cabin filter - RM 80
2.) Freon gas filter (little cylinder thing) - RM 80
3.) Local made compressor - RM880
4.) Freon gas recharger R134a - RM 60
5.) Labour - RM200
6.) Relay - Free but it's RM 30 if you guys want to know
Total damage - RM1,300
Results - Stable cold air and better cooling.
Thanks,
Ken
5.) Labour - RM200
Thanks,
Ken
Oh my! why compressor suddenly kaput.....:hmmmm:
Mitevo7
1,456
179
Hahaha magnetic clutch shaft shattered. Replacing the clutch is almost 600 bucks cause of lack of stocks. So it's better i change the whole compressor at 880. The aircond guy feedback that might be due some oil dripped on the clutch. Which is totally reasonable as i am having an valve cover gasket issue for quite sometime.
Thanks,
Ken
Mitevo7
1,456
179
So could be magnetic clutch fault all along, and finally kaput also.....lol
I would say its really a tough to make it kaput. It has been faulty for quite long time. Guess i am just lucky that it fail before i need to travel outstation. Now i can sort of drive without worrying.
Thanks,
Ken
Thanks,
Ken
Yah! if outstation fail, chialat loh! Hot some more......:smokin:
“Racing is dangerous, so please come back in one piece” was the order of the day before we were unleashed onto the Sepang International Circuit in Formula BMW FB02 race cars.
It really was as surreal as it sounds. Rewind back about ten days ago and it was just another day before the official invite came in. Being able to drive a Formula race car is one of the biggest moments in any petrol head’s life and...
