Need some info about brake pads
Trestor is the same as Bendix. If cannot find Trestor Blue Advantage, then get Bendix Metal King Titanium.
No, is not same. Even though same manufacturer in Malaysia, they are different. Bendix Metal King I think same as Trestor Metallic Plus only and Bendix General CT is Trestor Deluxe Organic.
Trestor Advantage pads is slightly higher than the metallic pads. I have used Bendix from Metal King Plus to Gold and then to Titanium then switch to Advantage pads. They bite from cold, and have better friction. Overall braking is so much better....:smokin:
Ic, then maybe the blue advantage is similar type like the Bendix Ultimate?
Blue advantage is cheaper. And Metal King is rubbish. Needs warmup to bite. I have used it before and it's dangerous when cold. No brakes AT ALL
If not mistaken, you were the first person I poison with Trestor Blue then later you poison the rest of the gang except bro. SF go buy different model......hhahhahahaha:rofl:
And was it cheaper, because that day when I bought for you, PH boss purposely off another RM5 or 10 to make the sale since you bought front and rear together.....:biggrin:
y2188
441
42
28
Yup, but cold bite is so much better.......:driver:
I'm currently using metal king, it really needs some heat to get it working :rofl: well from cold i still can stop the car pretty easily most probably due to my car is quite light....Really keen to try this trestor blue advantage on the next change :driver:
No need next change leh! Pads are not that expensive and you will love the initial bite and as well as the friction feel, meaning when you brake don't require more pressure than what you require for Bendix metal king.
Bro. Izso change over from his Bendix even though Bendix still new....hhahhaha:rofl:
Freaking idiotic Metal King couldn't stop my wira on a 30% downhill slope and I ended up rear ending a Hilux. He barely even felt the knudge and I was standing on the pedal already. My hood kemek and his hilux barely even moved.
That was the day I threw away the damn Metal kings and swapped to blue advantage.
KenDiriwan
1,283
225
kendiriwan.multiply.com
Bendix General is bullshit as well, couldn't provide stopping power plus ate/burnt my rotor like hell.
I could vouch for Trestor blue advantage the bite is real good. Only drawback is it is powderful.
Shinjite
864
120
Klang
So far I have only used Rapid Stop 550c and 800c pads. The 550c definitely not for competition/track use.
y2188
441
42
28
My current metal king few months old only leh :rofl: so far so good for me hahaha
Really that bad? is the rotor stock 1.5 size? previously i tried ebc green with my stock 1.5 rotors, not really biting that well too current 1.8 rotors with metal king bite better than that ALOT...
Totally agreed with the shitty performance of bendix general :thefinger:, my first set of pads, it's silent and not much dust though...:burnout:
550c not up to standard ah? Care to elaborate more?
Found this website and thought I should share it with everyone
DIY Paint Stripping
My car was a collection of primers, original green paint and rust, so it was decided that I would strip the paint to bare metal. The goal is to quickly strip the old layers of paint and primer and end up with nice clean bare metal. First off, as I've found out, there is no best way to strip the paint to the bare metal. All have problems. Here's a few methods:
Sandblasting
You...
