Press gas Pedal, car not moving
May 11, 2015
Hi guys,
I have a 2011 Nissan Juke.
But now car is stranded in workshop for two months, nobody knows how to work on it.
What happened is while on Karak, my car does not respond to gas pedal all of the sudden and the rpm stays idle. But the engine can start, but no response to the gas pedal. When brought to workshop, the mechanic told me it is ECU-related problem.
I really appreciate if someone can direct me to non-Tan Chong (nissan specialist workshop) or give suggestion how to handle this problem?
Thank you
ken yeang
6,618
1,327
is the car a gray-import? If it is, then there is a possibility that Tan Chong wont accept the car....
Waiora_ProTuner
619
221
I dont think Nissan Juke available officially through tan chong...
and there are no Juke club here...
15,390
I wonder if the TS will return to respond or ask more questions. I'm betting no.
My bet with a non-responsive throttle is probably some signal problem with the drive-by-wire. If modified with a DBW enhancer, remove that thing and try. If don't have one, then probably worth checking along those lines.
lady_nF
yup, Tan Chong did not accept my car....not even for quick check
---------- Post added at 09:03 AM ---------- 6 hour anti-bump limit - Previous post was at 09:00 AM ----------
no fault code?
no fault code, even CEL is not on...
the guy that I send this car to said it is ECU related problem...but he can't do anything because of ECU and immobilizer thingy...so he basically give up and I need to find another workshop
---------- Post added at 09:05 AM ---------- 6 hour anti-bump limit - Previous post was at 09:03 AM ----------
Did you try sorting this matter to Nissan itself ?
Nissan/ Tan Chong wont accept even for just check up
30,002
TS is back.....:rofl::rofl:
---------- Post added at 09:39 AM ---------- 6 hour anti-bump limit - Previous post was at 09:36 AM ----------
If ECU, fault code should show, right?
Maybe need to send to those mod shop/tuners, if regular mechanic cannot handle.....:hmmmm:
domomo
Sep 21, 2014
sorry ask noob question,is recond car or new car?
---------- Post added at 11:44 AM ---------- 6 hour anti-bump limit - Previous post was at 11:40 AM ----------
lady_nF
its a recond car
---------- Post added at 12:14 PM ---------- 6 hour anti-bump limit - Previous post was at 12:04 PM ----------
actually the workshop guy also suggested to do ECU pairing/reset (I am sorry, not really good in car lingo)
but he said the price to do it is too high and no guarantee if it will work, so he did not proceed with it.
When trying to move, the car will move and then sputtered for a while before the gas pedal become non-responsive.
15,390
its a recond car
My apologies for doubting your authenticity.
Out of curiosity, have you tried troubleshooting yourself? Like disconnecting the battery overnight to try to "clear" the ECU?
A quick google landed me this > Nissan recalling 909k vehicles globally over accelerator issue
Is your car affected by this since it's seemingly the same year? If it is, prepare to pay a lot to have it repaired since it's not warrantied.
ixeo
4,788
3,080
KL, Malaysia
If its a recall issue.. and your car is DBW... pretty screwed.. if its ECU only problem, you can put a Haltech Elite 1500 in.. but if the no-accel is also related to TCU as well then you can sapu KY jelly and bend over.
30,002
Since the Juke from Japan also......:driver:
hi all ,
recently i had my colt mirage a156 (1979) transplant to 4g91 carb , but it did save me any fuel , so i am thinking bout convert 4g91 carb to 4g91 injection ,
so i went on to study & research about the ECU , however i still hv about 10 pin-out on the ecu that i can't find the discription (function) . now i need help from u guys to help me , did anyone of u hv the 4g91 pin-out diagram ?
