When you get the car, I reckon the following:
1) Oil change / Oil Filter
2) ATF change
3) Brake fluid change
4) Power steering fluid change
5) Timing belt change
6) Timing belt related oil seals
7) Water pump change
8) LSD oil change
9) Coolen change
10) Air filter change (just change to K&N, no replacements after that)
11) Plugs change
Then you may want to check the following:
1) Brake pads
2) CV/drive shaft boot cover
3) Service/check aircond
On normal 5000km intervals, do the following:
2) Clean Air filter
Every 15K, ATF and LSD oil change. Otherwise, do the others when necessary. On the first service, prepare around RM2.5K. Good luck.
10000
