S Flow or Straight Flow exhaust
kipasa
Jan 28, 2013
18
503
Hi there,
Current satria setup 4G91 with waja crank shaft and oversize pistons running afc neo.
Extractor hotbits 4-2-1, custom middle pipping is 2 inch and comes with center box.
Current s-flow small and much back flow.
Cant make up my mind between a bigger slow flow inlet 2 inch or a hks silent hi power straight flow inlet 2.3 inch.
Need some advice.
Thanks.
Kipasa.
dking91
121
11
pekan
Hi there,
Need some advice.
Thanks.
Kipasa.
4g91 with waja crank??? 4g91 can mix with 4g18 mehh???
kipasa
18
503
oops its a 4g15.. so the 4g18 crank fits perfectly..
Mugen style exhaust hmm.. not sure can fit...
Cheers!
boyzone
2,669
5,148
Straight flow muffler is not a good idea for 1.5L engine.
Go for bigger diameter tri-flow muffler should able to serve u well ....:listen:
kipasa
18
503
Tri Flow exhaust.. hmm.. tried to google it, but cant seem to find it..
Will keep on searching :driver::driver:
Thank for the advice.
LittleWhiteWagon
1,656
187
P.J
Just get a straight flow muffler, you won't regret. 2.0" or anything below is good.
skyjuice678
5
Hi all,
Im using 4-2-1 and straight flow on my neo campro (stock). piping size remain original. Wat kind of setting should i go for ? Wat kind of center box should I go for?
*Daily car *good respond *sound not so loud
Hi, I'm planing to change my father's car, he is driving 10years old p1 iswara.
Looking at the new p2 looks good but want to get some opinion from all sifu here.
Thanks in advance for your opinion.
