illuminarias
Hi, I recently bought a set of AR Racing coilovers from rev performance and I installed them on my neo. The workshop however used a very high preload which resulted in a very very very bouncy ride. I've undone the preload (loosen the spring completely) and tighten it to a point where the springs to do move ( up down left right ), and tighten another 4mm. Now the car is much less bouncy than before, but it still bounces quite a lot compared to my friends ride with coilovers . Should I go with a 0mm preload or should I add more?
The dampening is at it's hardest (32). I do not mind if the car is stiff when going through bumps or potholes, but I do not want it to be bouncy.
Any ideas? I couldn't find any info about coilover set ups for a neo, and the neo section seems dead :C
