DIY LED brake lights. Need help.
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
Nice try bro...can you snap a pic of the wiring view from top..so I can give some input on how to improve the wiring section that you might miss...
stupidcar
5,000 RPM
5,567
850
Wiring section? I don't understand.
I think i too rush on this, made mistakes.
I punched the hole to near to each other. I nvr do a good measurement.
thats why using the breadboard easier...
can arrange then test...even can arrange as wording or symbol what... :biggrin:
bread board not that expensive also
Well, all these adds up to experience.
Btw, breadboard is plastic too right? Can it withstand the solder heat?
And plus, i just started to learn how to solder, i had a few cold solder. Bad. :bawling:
In a way, true also. The more you do, the more experience you get. Learn through mistakes....:driver:
shiroitenshi
3,676
170
you don't solder on breadboard.
a soldering aid like the soldering helper with arms are cheap rm20ish only and is a good buy if you solder often.
solder iron wattage also important. I use a 60-100w for car wires that are thick, and 25-40w for components.
stupidcar
5,000 RPM
5,567
850
PCB is different thing is ti?
I'm using 40W.
breadboard was designed to hold electronic parts and soldered...
one face plastic...another face got copper strip for soldering...
another type of bread board is cucuk2 type...just insert the leg...and good to go (self locking port)
stupidcar
5,000 RPM
5,567
850
With brakes applied.
Just with lights on, no brakes applied.
I decided not to post up the way i finished my project because it's kind of hazardous. It's not that waterproof.
If anyone wants some tips and tricks, can PM me. I will see if I can help out.
