like how the Japanese do ETC system... when buying JDM cars....
*I'll pay you for this*
ya ya... i'll pay too if someone can do that....
I'm sure many people already done this.
But here is how I did it.
Prepare the parts :- a 9V IC regulator. ***7809, 2 pcs of 100uF/16V e.capacitors, and a heatsink and pcb.
http://images.fotopic.net/yq8a5f.jpg
Then solder all the parts together. The IC pin when seen from front side is Input-Ground-Output. Connect the E.cap at input to ground and output to ground respectively.
http://images.fotopic.net/yq8a55.jpg
Buy the ciggarete jack (since im not smoking, better put it to good use) and open it up and rig a switch to turn it on and off.
http://images.fotopic.net/yq8a5s.jpg
Solder the input and output to the regulator. Need to cut the battery connector inside the battery compartment of the smarttag.
http://images.fotopic.net/yq8a57.jpg
On the battery cover of smart tag, u will notice a small notch. Cut it
out for the wire to go out.
http://images.fotopic.net/yq8a58.jpg
Finally cover it up nicely. Done!
http://images.fotopic.net/yq8a5c.jpg
And you will never need a battery ever again. Huhu...
Next DIY is to put a LED lighting to the SmartTag LCD screen.. hehe..
Use a rechargeable battery is a good idea. Unless got somewhere to hide like stupidcar suggested. If your cover is transparent
better stupidcar. So that infrared can reach.
I think is a good idea but not recommended. Will fry the chips inside later.
Like they said in car chargers are not good for our phone. Eventually our phone battery lifespan ends faster.
Voltage in the car is not stable. Can be high or low at times.
That where a calculations of resistor needed.
Put a resistor that resist 4 volts.
Car: 12V
Needed: 9V
Actually car is not 12V, car is 14.5V. 12V is the battery, once you start your car, the alternator kicks in and you get 13.5-14.5V, I always use 14.5v for car to calculate resistance required based on voltage and amp draw.
Sent from my GT-N8000 using Tapatalk 2
not really, overvolting leds a bit don't usually do much apart from shorter lifespan. overvolting a lot that usually kills it.
But yes, you can try with a multimeter to see before and after you start the car. its 11-12, before start, 13-14.5v after start engine and it runs the alternator.
dont test at the ciggy plug area, rarely you get full voltage unless its a new car.
But dude, i know input is more than 12V.
But output, the voltage is 12v right, TO those electronics(air cond, lights)?
Car: 12V
Needed: 9V
nope, most cars actually run fine with 14.5v, they were designed to, but they can also run with less voltage. Thats why I said if car, always calculate resistance required based on load using 14.5v
The battery is 12v. It only works to power the ecu, blower fan, lights, accessories, and the starter UNTIL the alternator takes over. The alternator will be the main source once engine starts, and the battery actually becomes a (consumer) or more accurately. a "load" on the electrical system in the car.
But this is also not 100% true that all accessories run 14.5v. Do remember that most car sensors runs on 5V, so your ecu does already have circuits to bring down the 12v/14.5v to 5v for the sensors. But never tap these wires for power, as the sensors use resistance/inductance/voltage to measure stuff, and you never ever want to simply add a load on its circuit.
Do understand that electronic do work in a "range" of voltages, not a single voltage. most auto specific electronics work up to 15v or 26V (for lorries)
You cannot consider voltage inductance and resistance in isolation as they are closely related.
Why so hard?
http://www.groupme.my/public/uploads/deal/Power-Adaptor-for-SmartTAG.jpg
Yes, but only if engine is off/alternator not running.So when I actually tap those electronics wires, its 12V ma. NO?
Always estimate for 14.5V for car stuff since you run most stuff with the engine on.
Those 12V they put on amplifiers is to simplify things only, they already design for 14.5+V
but seriously since got adapter, the only reason you'd want to do mod to smart tag is to relocate the sensor somewhere. I plan to do, but so far cannot find spoiled unit i can crack open and see.
prefer kl area...
