hi n good day to all
need zth opinion on dis matter..dis is my 1st time want to setup ice in old myvi. after do some google n reading dis is what i hv in my mind. i want to put an amp n cs only so no hu..but if got opinion for new amp n cs with good quality n performance dat can low my budget pls let me knw. aso can i knw gross figure for installation of the amp n cs in kota damansara n b.jalil area (as i read this post, most ppl propose CV Audio Uptown Damansara n EA Autoworks Bukit Jalil) tqvm![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
amp is choice between dis 2
1) JBL GTO-804EZ 4-CHANNEL CLASS A B CAR AMPLIFIER (RM800)
Features:
•4-Channel GTO Series Class AB Car Amplifier
•RMS Power Rating:
4 ohms: 80 watts x 4 chan.
2 ohms: 100 watts x 4 chan.
Bridged; 4 ohms: 200 watts x 2 chan.
•Max power output: 235 watts x 4 chan.
•LED power (green) and protect (red) indicators
•Variable Bass Boost (0 to +12 dB bass boost at 50Hz)
•Soft start turn-on
•Gain LED indicators for proper gain adjustment
•4/3/2 channel operation
•Heavy duty aluminum alloy heat-sink
•Nickel-plated RCA level inputs & screw terminals
•Input sensitivity:
Low level: 125mV-5V
High level: 250mV-10V
•Variable low-pass & low-pass filter (40-220 Hz, 24dB/octave)
•CEA-2006 compliant amplifier
•Frequency response: 20-23000 Hz
2) PIONEER GM D8604 RMS CLASS FD 4 CHANNEL AMPLIFIER (RM780)
Features:
GM Digital Series 4-Channel Class D Car Amplifier
RMS Power Rating:
4 ohms: 100 watts x 4 chan.
2 ohms: 150 watts x 4 chan.
1 ohm: 125 watts x 4 chan.
Bridged, 4 ohms: 300 watts x 2 chan.
Max power output: 600 watts x 2 chan.
Pulse Width Modulated MOSFET power supply
Wired remote bass level control included
Speaker-level (high-level) inputs with signal sensing for automatic turn-on
Preamp RCA outputs to daisy chain multiple amps
3-way protection circuitry (thermal, overload, and speaker short protection)
High-density split-dome convection heat-sink for extreme heat dissipation
Input sensitivity:
Low level: 200mV-6.5V
High level: 0.8V-16V
Variable high-pass & low-pass filter (40-500 Hz, 12 dB/octave)
Frequency response: 40-50,000 Hz
for component speakers i choose dis 1 but i think its kinda expensive
INFINITY KAPPA 60.9CS 6.5 COMPONENT SYSTEM SET (RM650)
DESCRIPTION:
The component system includes; 2 Woovers, 2 Tweeters, 2 Crossovers
6-1/2" / 6-3/4", 2-Way Car Audio Loudspeaker component system
Low-distortion, low-Q woofer motor
Plus One woven-glass-fiber woofer cone with hi-roll rubber surround
1" Ultra-high frequency textile dome tweeter
I-Mount tweeter-mounting kit with Starfish O.E.M. adapter
Adapters included for most domestic and imported applications
2-way external crossover network with tweeter level adjustment, poly caps and air core inductors
True Four Ohm Impedance technology: speaker's 2-ohm impedance combines with speaker wire impedance for a 4-ohm load
Compatible with virtually all factory or aftermarket car stereos)
Sensitivity: 93dB
Frequency response: 45Hz-35kHz
Power handling: 90W RMS
Power handling: 270W Peak
Top mount depth: 2-7/16"
Features:
•RMS Power Rating:
•Soft start turn-on
•Input sensitivity:
Low level: 125mV-5V
Features:
RMS Power Rating:
Input sensitivity:
DESCRIPTION:
Sensitivity: 93dB
