But claying more for surface contaminants only, like rough surface that you can feel. Water marks better use polish to remove....
yes, that is true but the water marks i'm talking about are not the permanent type. you know when you use a wet cloth to dry a window and after it dries you can still see dry water streak marks on the glass?
it's the same with the car body. so these are not the type of marks that need polishing to remove.
having said that, my car's paint is bad in need of a polish......lots of surface defects. this is the one thing i don't have time (or know how) to do. prefer to get someone else to do it. but difficult lah. most of the really good detailers that i know don't have a shop and they do it at your house. problem is my house doesn't have covered porch and they need one full day to do polishing. haih!
nolah, just that i like the after effect of claying. i find that washing doesn't completely clean the car. and this is partly due to the quality of water supply from our taps and i cannot satisfactorily keep a micro fibre cloth super duper clean no matter what i do. when i dry the car, i can still spot some dirt left (tiny little watermarks). with claying, i seem to have a lot less of that problem. that's why i was thinking of claying during each wash.
i park my car in the open air because my house doesn't have a covered porch. i have parked my previous rides before before in my house porch over the years and find that after a few months water marks will appear on the glass and it cannot be removed (except with something very acidic or by some intense scrubbing / sanding of the glass - but that's another story). after speaking with bro KC he said it is likely caused by rain water dripping down or splashing off from the roof, walls, etc of my house onto the car. i've spoken to another megiuars detailer before and he said the same thing. it's either from the house or tree sap (since no tree so must be house). that's why i park my car by the roadside outside my house.
so the car is super exposed to rain and sun. :(
Need to fix a gutter on your roof edge to channel the water somewhere. Also put on a coat of waterproofing layer before you paint your walls with weatherbond...
Do you use OCW regularly after every wash or so? Or is it plain opti-seal?
May i suggest you try other sealant/waxes instead. My opinion, opti seal is good and easy to use but does have its weakness too (don't want to elaborate, different people different criteria). Try other wax/sealants instead to see if it works better for you.
Since we're on the topic of claying - I wanna ask about using ONR as lube. I noticed that ONR will streak if it's left to dry on its on and according to the instructions it's best to wipe it dry as soon as possible. Does this mean then the process would be clay + ONR lube then dry?
Also what is your ONR mix proportions? 1 part to 3 parts water?
just to share,
I have clayed a BMW 318 before (year 1995-1997).
It was repainted sometime in 2005 to purple and the bumper didnt have clearcoat.
I was claying the bumper and all of a sudden my white clay turned purple.
i clay all the cars i do with only water =.= ONR is overrated, and spraying ONR dillution for claying? =D try it with water then try it with ONR then u tell me whats different
I would love to see some scientific test on marring: claying with lubricant and claying with just H2O. But intuitively, claying with lubricant would reduce the risk of marring. Personally, I clay with water only. I too do not notice any difference compared to when I clayed using lubricant -- but it could all boil down to technique.
*slaps forehead*
So even claying is a voodoo science topic ah?
s1tl : I sometimes use OPC to clay because it's silkier. But I have to rinse immediately after and that's highly time consuming. Do you clay with a running tap or just dip rub dip rub style?
*slaps forehead*
...and some people would question why you kacau kopi clockwise and not anti-clockwise....
*slaps forehead*
Er.. considering I've only done this twice, I don't know.Your claybar wont spoil ar?
Will someone tell me how to clay properly?
