4G92P N/A Or BOT
Jbdragster
Hey guys!!
Saya baru lagi dalam dunia modifikasi enjin ni..sy menggunakan enjin 1.6 sohc (4G92P) pada satria saya.
sy ingin menambah HP pada kereta sy patutkah sy BOT kan atau stick pada N/A
Mintak pandangan utk N/A nak masuk barang apa bagi cun + HP..
Mintak pandangan utk BOT nak masuk barang apa..
budget utk engine upgrade RM5000: :confused:confused:
i think yr budget isnt enough to make 180hp NA.
better BOT then.
i noticed dat 180+ is too high n much HP..but i more prefer N/A...can easily go 200kmH should be ok...but what should i set in?any suggestions?
owh...but if i wanted to stick on SOHC shoud i upgrade the cam , distributor , air intake , bigger throttle body , injectors or etc? ECU also change rite?
any recipe sifu?
btw thx for the link.. i look forward if i dont wat to use SOHC any more...:biggrin:
and how much its cost too...
huhu
Oh, am not familiar with sohc mods.
Let other sifus to help you.
charging it will give u better torque and power,better fuel economy,and will be cheaper den forcing a 93 to churn out 200hp,iam just saying..
Ok ehdrian..btw thx for ur other opinion..really apreciate it man...
:wavey:
---------- Post added at 08:05 PM ---------- 6 hour anti-bump limit - Previous post was at 08:03 PM ----------
Ohw...so how much will it cost to BOT my engine ?
Any parts list u have in mind instead ?
Heheh
SOHC not meant for mod. Keep as NA. If want upgrade to DOHC
target hp kne kurang kn skit..rse nye plg power org buat 4g92p na 160hp...
kalo ikot idea sye
1- tukar sistem exzos
2-lighten flywheel(skim)
3-rebore(82mm/83mm)
4-high compression piston
5-bigger injector(240/270)
6-bigger tb(60mm)
7-head port&polish
8-tuning(rechip/remap/emanage)
sye pon pkai 4g92p tp xda mod byk sgt pon..bru overhaul, 82mm piston, flywheel skim sikit, skim head, exzos sistem..
dri auto tukar manual
kalo total kn sume duit yg abis, blh angkut halcut mivec doh sbnr nye..tp yg pntg kepuasan dan menimba ilmu :)
pendapat newbie yg bru join :)
kalo ikot idea sye
3-rebore(82mm/83mm)
6-bigger tb(60mm)
7-head port&polish
saya ada buat list sikit..but xtau la padan ke x..antara barang saya nak masuk adalah :
1: High profile cam shaft 280 maybe (include cam pulley/crank pulley pon tukar skali)
2: Intake manifold (skunk 2 kalau boleh masuk)
3: Injector for sure
4: Fuel Rail
5: Clutch kit (super single maybe)
6: Tb ape brand yg sesuai?
7: Port Polish head (but xtau nk hantar mana area JB/P.gudang)
8: Ekzos sistem (4-2-1 or 4-1)
9: ECU (pakai apa bagus?)
1.high cam: comfirm nk pkai high cam?? minyak parak... cam stended pon dh ok.. 252in/248out
2:xpyh pkai brg skunk2 yg mengarut 2..tiruan sume...selagi intake asal support mod yg dibuat, gnekn je
3:210cc pon dh ok..sye pon pkai yg asl lg
4:fuel rail:sye xnmpk pe keperluan menda ni..bkn racing car kn???
5:clutch:ok jgk..tp blh tahan ke dlm jem? :)
6:cri tb perdana sei 2.0
7:anta ke nasty port flow/powerzone
8:4-2-1 powerzone extractor+1.8 piping+ 2inci mid-bullet+2inci muffler inlet(kalo heavy mode,size piping blh 2inci)
9:safc 2 pon dh ok..nk pkai emanage rsenye xblh nk tuning ignition sbb pkai distributor stended bkn coil(xpasti)
yeah mmg kena fikir semula ikut keperluan mode. sy pakai cam 272 mmg bnyk membantu la dlm increase hp tp kena sacrifice fuel consumption sket.
bro rebore piston pkai model sama gak @ performance? costing? sbb belum tergerak nak tuka block 1.8 lg hehehe
get mattspeed camshaft.. they are vary familiar with sohc camshaft modification. they can even produce as high as 305deg for sohc engine. can look at mudah for details. one of my friend mod 4g92p with wira aeroback and quite fast.. go seek Along RMD at perling for more advise.
---------- Post added at 11:33 AM ---------- 6 hour anti-bump limit - Previous post was at 11:30 AM ----------
matspeed already made 320deg for 4G sohc full race setup..
sry late reply...4g92p was blown up..one piston gone :) i was using cap ayam sakura piston bore 81.5.. now upgrade to 4g93 sohc...bore 82mm 1.6 sohc toto piston...can use TRIM brand also...i heard ppl make 150hp+ on 4g92 by using trim piston....
management maybe can try MS2, which has wider n more tuning points.
As for hardware, high comp piston, harder valve spring, and better,in
