im a newwbie here, whats the best exhaust system for my stock sgti? :)
Hi,
Need clarification... which is the best setup for satria neo manual. now using 4-2-1 stainless steel extractor,1 midbullet, 2.0inch straight pipe goes under the fuel tank and a muffler with 2.2inch inlet or just using the current setup but the exhaust piping follows the original route which got bent 90degree before the fuel tank. Btw, my fuel consumption is very bad i think (but the fuel consumption indicator shows 5.9l/100km). I manage to finish RM30 RON97 within 2 working days which is around 44km per day. Or it is because the engine oil?? using motul fully synthetic 10w40v?
Thank you.
Definitely w/o bend is better. And I say go for a larger diameter for better top end engine breathing.
Eh you pump RON97, which is equivalent to 11 litres. you travelled 88km. So 1 litre for roughly 8km which is normal.
so rm30 ron97 for 88km is considered normal lah..
bro, mind to tell why larger diameter pipe? my friend said, 2.0inch is just nice for 1.6l modified car. even he uses 1.8inch diameter pipe after midbullet...the bigger diameter, the slower exhaust flow.
thanks.
Hi,
Thank you.
Hello members,
I'm a newbie here driving a stock toyota corolla ae92(cielo) which uses stock 1.6litre engine. I'm thinking of upgrading my exhaust system for some power and also a bit of oomph sound.. What is the best thing i can do w/o killing the fuel consumption?
Similar threads | |
