Does Anybody Got Mitsubishi V6 Engine Details
Engine layout with gearbox on lefthand side@wira layout
6a10 dohc-1.6
6a11sohc-1.8
6a12dohc-2.0(twin turbo/mivec/mivec md/non mivec)
6g71-2.0
6g72-3.0(twint turbo & na)
gearbox on right hand side@gen 2 layout
6a11 sohc -1.8
6a12 dohc - 2.0(mivec/non mivec)
6a13 dohc - 2.5(twin turbo/na)
6g72-3.0
6g73-2.5
6g74-3.5
6g75-3.8
both 6a and 6g could swap all parts within their family grouping according to engine layout/production year.example
hybrid a 6a12 mivec head with 6a11 block makes a 1.8 v6 mivec dohc.hybrid it with 6a12 turbo kit it becomes v6 mivec 6a11tt.ecus and gearboxes are interchangeable.
Most parts from 6a arent interchangeable with 6g.
6a & 6g have different mounting layout.
6a12 mivec fto is not the same as a 6a12 mivec galant.fto has a transverse engine
6a13 will never pnp into a perdana because its a transverse.major mods needs to be done
6g needs mods to be fitted into a perdana.engine is very wide
6a11 transverse can be fitted into waja/gen2/persona its 1.8
---------- Post added at 03:22 PM ---------- 6 hour anti-bump limit - Previous post was at 02:38 PM ----------
Vr4 doesnt refer to 4g63t before evos
it refers to a 4wd turbocharged engine such as
6th generation galant vr4 = 4g63t 4wd
7th generation galant vr4 = 6a12tt 4wd
8th generation galant vr4 = 6a13tt 4wd
legnum vr4 = 6a13tt 4w
if its not a vr4 it means its not a turbo.but it could be either a 4wd or a 2wd
its funny that malaysians refers a vr4 as 4g63t ONLY....
Any Sifu here can direct me where can i buy ECU for V6 DOHC 24Valve??
the ECU board burned, find out that water is dripping inside and the whole circuit board burned.. Zzzz
please help advice, thank you.
ECU board number:
1. 0480 / MD180480
E2T38771
ECU board number:
1. 0480 / MD180480
E2T38771
bro u can try at marketplace or mudah.my
1.8 V6 SOHC model form GALANT
Displacement, cc 1829
Engine model 6A11
Max.power (Net), kw(PS)/rpm 135 ps (99.29 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 17.0 kg*m (166.71 N*m) / 4500 rpm
Power density 8.89
Engine type V type 6 cylinder SOHC24 valve
Engine information
Fuel system ECI-MULTI (electrically controlled gasoline injection)
Turbocharger No
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) No
Compression ratio 9.5
Bore, mm 75
Stroke, mm 69
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 7.2
6a12 V6 SOHC model form GALANT
Displacement, cc 1998
Engine model 6A12
Max.power (Net), kw(PS)/rpm 145 ps (106.65 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 18.5 kg*m (181.42 N*m) / 4500 rpm
Power density 8.34
Engine information
Turbocharger No
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 7.5
6a12 v6 DOHC
Engine model 6A12
Max.power (Net), kw(PS)/rpm 170 ps (125.04 kw) / 7000 rpm
Max.torque(Net), N*m(kg*m)/rpm 19.0 kg*m (186.33 N*m) / 4000 rpm
Power density 7.53
Engine type V type 6 cylinder DOHC24 valve
Engine information
Turbocharger No
Fuel type Unleaded premium gasoline
Compression ratio 10
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.8
MIVEC MD V6
Engine model 6A12
Max.power (Net), kw(PS)/rpm 200 ps (147.10 kw) / 7500 rpm
Max.torque(Net), N*m(kg*m)/rpm 20.4 kg*m (200.06 N*m) / 6000 rpm
Power density 6.35
Engine information MIVEC-MD
Turbocharger No
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8
VR4 V6 TWINNTURBO
Engine model 6A12T (twin turbo intercooler)
Max.power (Net), kw(PS)/rpm 240 ps (176.52 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 31.5 kg*m (308.91 N*m) / 3500 rpm
Power density 5.96
Engine type V type 6 cylinderDOHC24 valve IC twin turbo
Engine information
Turbocharger Twin Turbo with intercooler
Compression ratio 8.5
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
6a10 V6 DOHC
Displacement, cc 1597
Engine model 6A10
Max.power (Net), kw(PS)/rpm 140 ps (102.97 kw) / 7000 rpm
Max.torque(Net), N*m(kg*m)/rpm 15.0 kg*m (147.10 N*m) / 4500 rpm
Power density 7.71
Engine information
Fuel system ECI multiple (electrically controlled gasoline injection)
Turbocharger No
Bore, mm 73
Stroke, mm 63.6
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.3
6a13 TWINTURBO
Displacement, cc 2498
Engine model 6A13
Max.power (Net), kw(PS)/rpm 280 ps (205.94 kw) / 5500 rpm
Max.torque(Net), N*m(kg*m)/rpm 37.0 kg*m (362.85 N*m) / 4000 rpm
Power density 5.29
Engine information
Bore, mm 81
Stroke, mm 80.8
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 10
3.0 V6 6G72T twinturbo G.T.O
Displacement, cc 2972
Engine model 6G72T (twin turbo twin intercooler)
Max.power (Net), kw(PS)/rpm 280 ps (205.94 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 43.5 kg*m (426.59 N*m) / 2500 rpm
Power density 5.89
Engine information
Compression ratio 8
Bore, mm 91.1
Stroke, mm 76
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 12.5
