Performance camshaft OR PnP Stage 3
crazykatak
776
48
Subang Jaya
Hi, i owned a neo cps(m), lightly mod(fuel regulator, cam gear, lighted cam pulley, drop-in k&n, 421 header, EMS1.
The problem is my car cannot go more than 180kmh. Other gears can go to 6.5-7rpm but when in 5th gear rpm drop to 5.5 when speed is 180kmh. Any other cps experience this?
My question is, does neo cps have speed limiter? Can i remove it? And what is the best next mod to increase performance?
Try to work on the cam settings 1st. No point if the settings are incorrect / not precise but you go change the crank pulley..additional time and money spend.
Perhaps..
due to the nature of the gearbox, limiting the top speed to just 200-215 kph..
neohadri
200
34
ya Izlan, i suspect it's ur LCP, so sell it to me cheap2:tongue:
Izlan Rashid
From Facebook
May 14, 2011
19
www.facebook.com
Perhaps..
Bro, i tried few difference settings. Not much different on top speed. Which setting works best for u? U dont think it is the lcp that cause this? How about the lack of power going up hill?
Thank u in advance bro
crazykatak
776
48
Subang Jaya
Remember. Never blame the hardware that u have..
Going uphill with a lightened crank pulley should be easier..as there's more torque at lower / mid RPM range.
To me, there's no one setting that fits all.
There's no such thing as i gain good top speed & gain good pick up at the same time.
It does not work that way bro..
I can not recommend any set up..as you already have a piggy back. Go ask your tuner. Or re tune you EMS.
AhLun
284
2
3,018
JB
Just curious about changing to a bigger size piston or high compression type. Can CPS crankshaft able to hold it?? Any bro tried before? Actually what is the actual size of the original cps piston?? How big can it change to?
nadziad
287
28
johor
i tthink may be the lighted cam la.....mine stock cam can go up to 200km....no ems no piggyback...just metal drop in filter, iridium plug, volt stabilizer and cold air intake
crazykatak
776
48
Subang Jaya
Yes
Yes
76mm
76.25mm
76.50mm
76.75mm
77.00mm
ronzai89
30
Always focus on intakes 1st. then only do up on your exhaust.
whats the point of having a big pussy but a small dick right?
SpeedJunkies
Dec 6, 2010
7
Where do you stay ? if Klang Valley , I can bring you to a few satria neo's workshops and you can ask them and compare it :)
Dori-Dori ( batu tiga , shah alam )
Wazi ( Kota kemuning )
Gcar ( Old klang road )
