imho, both ecus can be used with the mivec head. however you will need at least a piggy back ECU like e-manage to control mivec (if use gsr ecu) and fuel correction after mivec opens with the turbo. If you use mivec ECU you need to buy the optional emanage external map sensor to correct the fuelling of the stock NA Mivec ECU. Both used stock ECU aren't cheap these days. you can consider stand-alone management if your budget allows.
Microtech LT10s 25psi MYR3200.00 onwards
Haltech Sprint 500 1.5bar MYR2888.00 onwards
another method is save your money from buying the ever rare mivec head. Invest instead in performance camshafts kit like Duratech, JUN or TOMEI made for the stock 4G93T head. Prices are from MYR2100 and beyond. That will give you more top end power. The only disadvantage comparing these cams to mivec head is the low end power and fuel consumption. Otherwise you can have a sick idling sound and better top end power.
The exhaust manifold for GSR (3mm) in my experience the RM750.00 ones are ok to use but recommended that you skim the flange for flatness before installation. That alone cost MYR100+ to do already. Otherwise you can try ask supercircuit guys if their manifold requires such thing or not. Also, you need to buy the steel exhaust gasket for good sealing. Thats all.
thx alot bro...i think just change a high cam will do rather than find a rare mivec head....high cam have few not same degrees rite..?which 1 should i choose...?can i just remap my ecu after changing high cam cuz not too much bugget now...?n wanna confirm that evo 3 turbo flange same as gsr...?
