here's a rough idea of how it should look like...
Google Image Result for http://www.himni-racing.com/images/Tial_44mm_inlet_outlet_clamps.jpg
I saw them in Enous before (1 utama). But it is closed for reno now. Maybe you can try the other Enous.
yaa man..my decision to build up the 4g93t terbalik frm scratch def v confusing..tomo going to have to go library and read some more..nvm wait i fed up i chuck to my foreman..hehe..thanks bro
hello guys I'm planning to do 4G93T with Mivec head 4G92 DOHC. I will be using Wiseco Turbo Pistons 81.50MM 0.5MM oversized, Duratech Conrods, ACL Race bearings and turbo not decided as yet. What parts will be replaced in this conversion any idea ? I will be using 4G92 DOHC Mivec Head, 4G92 Mivec wiring, sensors and ecu. 4G93 Block, pistons, conrods, bearings and head gaskit of 4G93T most probably 2.0MM. What else will I be needing ? I have a confusion in my mind which water should I use ? 4G93 or 4G92 DOHC pump ?
This is the terbalik version aka CM5A and CK series ? Or the older CD5A series ? I think u need computer management since ur mixing mivec and 4g93T tech, u could try askin a few sifu who manage to mix n match successfully, as far as i know if u use mivec ecu, how can it control the fuel ? Turbo need very good fuel control le too lean or too rich and u will have problems later. Most of the problems come if ur too lean tho, rich usually is ok.
Just wan to reconfirm, anyone encounter abit of engine whine ? Not the tepet sound it's abit like grinding sound. I change everything like bearing, belt, only cam gear didn't change. When idling can hear like grek grek grek den nothing den grek grek grek den nothing. I try to get the sound later once the car is in my hands now tidying up the interior and finishin sum touch up.
Anyone can share what item u guys use to stick into the ori bypass valve hole ? I found those rubber stopper from plumbing shop but my mech say it's too soft, scare it might not stand the heat and melt or get sucked into the turbo.
Thank you sir for your kind reply. I am using CK4A as it is a Mitsubishi Lancer 2006 Model. I will be going for a standalone ecu for tuning[Fueling, Timing..etc]. But I need a good standalone ecu which has every function anti-lag, stepper motor, launch limiter, mivec controller etc. My aim is for drag no streeting. I have a GT30R lying with me but need to change its housing as it is too big any suggestions for housing ? One thing more can I start my car and run perfectly with stock ecu. The engine came up with Automatic transmission and I am gonna swap manual gear box. Is it just plug in manual gear box or do I need to play with wiring ? In mitsubishi do they have the same ecu for auto and manual transmission ?
hi wanna know 4g93 gsr n 4g93 gdi turbo manifold the same?
a 4G93 GSR manifold will NOT fit a 4G93GDI without modding tge location of the turbo, etc..I assume this is e CS5A
---------- Post added at 08:00 AM ---------- 6 hour anti-bump limit - Previous post was at 02:40 AM ----------
forgot to add..if u want the downpipe frm an airtrek turbo will fit
hey guys.. does the auto gearbox for 4g93t last long? because i m thinking to get an used car with 4g93t auto...
thx for ur answer =p
