I suppose your TPS sensor got a lot of electrical noise. Your ECU may think that you are at idle even you have your throttle slightly open. In this case to 1600RPM. Since you mentioned that your TPS voltage at idle is 0.5v. Try adjusting the TPS slightly to solve the problem. Bring it up to 0.6v at idle and see if that solve your problem.
I'm having a serious problem, can someone tell me where i can get mivec rocker arm??
just get the front twinpots from Evo3 and replace with oem ones..the rear brakes shud be good enough even if it's stock..wat car r u driving btw?..
Problem now is sourcing it sumtimes it's ez sumtimes hard. 4 Lug or 5 Lug no prob as I got few sets of rims from other cars.
u frm whr bro?..half cut shops got a lot..
Btw bro ur car using what brakes ? Evo 3 ? Saw ur car pic on ur 4 sale thread.i got a set of evo 4 front brakes... pm me if interested.. new pads mkt, just use for few weeks, reason for selling, upgraded brembocheers
and for ur info, jpj usually fail rear brake cause tarik hand brake x makan, damn, they dunno the fact that the cable disc hand brake will never makan like drum brake or hydraulic hand brake
brembo are not cheap, i sourced 1 year plus and get front and rear for 2.8 k include pos fees, 2 pot is enough , unless u got lots of horses, those brembo are heavy , i admit it, but i am running with e4 power plant and 4wd, i come across lots of fade (always full meter), that is why i upgrade..... for u, i will suggest evo twinpot with good pads, for ur info, both e3 and 4 2 pot are same, akibono 2 pot caliper, different in rotor size only, in conclusion , even u got good brake , jpj will always fail u, unless u give ur upgrade money to them, sure pass uand for ur info, jpj usually fail rear brake cause tarik hand brake x makan, damn, they dunno the fact that the cable disc hand brake will never makan like drum brake or hydraulic hand brake
. So i guess now is just to service up the car and maintain for now.
Solty8: h/cut got evo3 brakes leh, evo4 also got..my car can pass jpj, using gsr with standard brakes..
anyone know where to get apexi eletronic boost sensor ? At the same time anyone also know where can get Greddy Bov Type RS tapak ? The bov tapak i got is for subaru which I curi from my bro. Else might be salvaging parts from another car.anyone here know where to get v-band clamp usually used on wastegate downpipe..??
i've got someone telling me at hydraulic engineering shops...
any other suggestions...?
here's a rough idea of how it should look like...
Google Image Result for http://www.himni-racing.com/images/Tial_44mm_inlet_outlet_clamps.jpg
