buying a corolla seg AE111, what do i look out for?
loupho
hi to all the sifu sifu..:adore:
i will be looking for my 1st toyota and it will be a ae111 4afe. i think. what are the things that i should be looking for in a second hand car ? how will i know that its no major accident? what are the most coment things that spoile for that car? is the car reliable ? oh, and its going to be a AUTO..
thank you all the sifu sifu:adore:
hope i can fine 1 with a 4AGE 20V BT inside..:biggrin:
---------- Post added at 02:08 PM ---------- 6 hour anti-bump limit - Previous post was at 12:53 PM ----------
anyone ??:adore::adore:
We (maybe for me only la) can't really know how good the condition of the car and engine. What I did was i brought a 'magat' fella and my mech. 1 person check body and 1 person test engine/drive car. Both fellas green light-> DEAL. all the best!
look for oil leaks, unusual dent inside the car & engine bay..
check engine oil, transmission fluid, brake fluid.. everything la..
dont forget to bring ur torch light.. a very bright one.. (i'm selling at rm15 only.. hehe)
if u got 4age BT inside then u need to pay for RM2.70/liter RON97 ohhh......think twice...kekeke..:)
---------- Post added at 05:34 PM ---------- 6 hour anti-bump limit - Previous post was at 05:30 PM ----------
hi... between i got a fren wanna let go his AE111 96' with 4AGE BT auto inside. just converted bout 1 or 2 yr ago...interested? just leave me ur no and will ask him to contact u... it's a nice and consider vy stock family car with vy good care maintenance.
loupho,
follow j_l200s, advice bring a mech if you find a good looking AE111. body check easy ,check along the rubber seals, open it look for sign of dent or weld, try open shut door, if the door feels haevy than most likely its been accident and done paint job with too much plaster.
suspension dead give away, push the bonet and boot if too bouncy need to change, if too hard no comfort at all. alignment need to drive 100km/h and see.
By the way 20v BT no need ron97 cause ron95 also can use one,2years already no problem.
thanks sifu sifu... but the car that i know now is at a use car place at serdang.. and my house is at kepong wo.. how can i get a mech to see the car ?? i am really noob in this. 1st time buying a second hand car. how can i know its not a " potong car ? " see under the door ruber ad.. under the car capet ? thanks to all the sifu sifu ah..
---------- Post added at 12:09 AM ---------- 6 hour anti-bump limit - Previous post was at 12:07 AM ----------
loupho,
what you mean by suspension dead give away, push the bonet and boot if too bouncy need to change, if too hard no comfort at all. ???? thanks..
:adore::adore::adore:
Some people said AE111 got rusting problems. Try look out for em. And, Check the frame and roof for any signs for irregularities or knock repairs. Check for consistency at the door gaps.
I learn things th hard way. When I bought my AE111, it was very well done to cover up the accident. When my mech see it recently, he told me there is a high chance this car rolled over. I was like @.@ damn that salesman.
loupho,
Hope can explain it to you clearly, here goes.
The main component of the comprise of absorber and spring if the absober is worn out ,than there will be no absorbtion when u push the car down at the front and rear, it will be wobbling there will be very easy up and down motion to push the car.
If the spring is too hard (modified) you can hardly push the car down, imagine riding an old bicycle with no absorber and spring on a rough road it will be the same feeling(uncomfortable).
i pm you my number all ready.. pm me back your friend number.. thanks...
AE111 no need go until Serdang gua...I have seen a few around Kepong area used car shops also...
Mudah also can search a lot hehe!
the car that i see is at mudah. how much do you think that a ae111 will cost ? a 96-97 model.. :hmmmm:
Depends area... Generally Sabah is much more expensive than west. I got mine for 23k. That is the cheapest in sabah already. Condition okay, but have to spend at least 1k to replace oil seals, service and stuff. Those with blacktops a bit more expensive la... But syok ma :biggrin:
i found a ae111 1.6A 96 only going for 20.500k only.. is that cheep or okok only or have probem 1, like accident beforo?
over here at kl have this shop that specialise in 4age, "kegani" for 5k servicing is around rm230-rm250. is that ok ? :adore:
---------- Post added at 11:33 AM ---------- 6 hour anti-bump limit - Previous post was at 11:29 AM ----------
and 1 more thing.. is 4age 20vbt fuel eco. ? vs 4afe. for normal drive.. city drive.. thanks.. and the reliability of the enjin 4age20v bt vs 4afe... thanks :adore::adore:
Bro I don't know KL standard price for servicing. But RM200 is a lot! And servicing is a fairly easy task that you can do yourself. My servicing cost around 80 - 100 using 76 brand semi-syn oil. No labour charge because I go to the authorised dealer of the 76 brand oil. And the mech even told me I can service every 8k km because I use semi syn. ButI never do that la... Max 7k km I will feel damn guilty and service it :biggrin:.
And for those 2 engines, they are like tanks. I've been whacking my 4AFE but it doesn't break.
the best way to spot a 'kereta potong' is to look under the car.. see if there's any welding from 1 side to the other..
if not, look under the rubber thingy beside the seat (front & back) below the door.. got welding or not.. if got, DONT BUY..
Gudluck :burnout:
and for the suspension.. push down hard & let go..
if it goes up & stay, the suspension is good..
if it goes up & down & up again, not good..
:adore:Originally Posted by loupho
and 1 more thing.. is 4age 20vbt fuel eco. ? vs 4afe. for normal drive.. city drive.. thanks.. and the reliability of the enjin 4age20v bt vs 4afe... thanks :adore::burnout:
1. Toyota SEG '96 AE111 4afe - RM 20.5k = standard price.. in mudah.my have RM 19.3k.. (dont know about the condition.. must see for urself 1st)
2. "Kegani" shop in KL.. dunno.. must see for urself also (sorry)
3. 4age 20v BT vs 4afe.. hmmm..
4age is a race engine.. light internals.. high horsepower rating.. i've used it on a AE92.. fuel consumption superb..
4afe is a everyday car engine.. internals ok.. horsepower rating not so high.. never use it but i think the FC is ok..
both engine are reliable..
Gudluck :burnout:
Gudluck :burnout:
I didn't notice before this d7zul... Your avatar... IS it AE101 Levin BZR?
Write your reply...
