Car shaking when engaging 1st gear
It should only occur when at the biting point. If its jerking when clutch is fully engaged then its definatelysomething wrong man..
ok its like this the jerking gets worse as i release the clutch on low rpm
it goes away if i press down the clutch or rev the engine higher while the gear is engaged
yeah me too.. vibration happens at the biting point of the clutch, happens very early.. and my clutch is about 3 months already and the car is daily driven.. g/box mounting also changed..
From what you discribed, sounds like it's the charecteristic of your racing clutch cos racing clutches are supposed to bite with more grip. It takes a bit of getting used to. You have to disengage a little faster in one smooth motion.
this sounds about accurate coz this only happens in my first and second gears coz i release it pretty slowly then
but 3rd gear onwards quick shifting :biggrin:
do u experience the vibration while engine braking too? i get vibrations when i downshift from 4th to 3rd gear, and it happens at the clutch biting point just like when im upshifting..
frust wooo when driving smoothly, then wanna downshift n layan corner it vibrates! now must drive like old man :banghead:
Thats why when driving hard and downshifting, the heel & toe technique should be applied for smooth down shifting. :driver:
hey E3newbie, i should be named newbie on this topic! hehe still cant brake smoothly with my toes, need more practice.. with the clutch problem, i have a reason to practice heel-toe on all the corners i see :driver:
Write your reply...
