To take care of turbo engine
melanz
6
Tawau
I choose to use 4age sivlertop with addition of turbo charger. How to take good care of this type of combination. plz give advice:driver:
turbolover
1,185
112
Eh nobody seems to be answering this thread yet.must be sunday and everyone went out for sunday drive and i'm stuck in office working.hehe.
anyway if u r still with stock internals, keep the boost low.tune it properly and do frequent oil change.as for others must wait for the sifus to comment.
turbolover
1,185
112
What to do if not no money to pump petrol.haha.want to change bigger turbo also so got to work harder.
xtremeleo
3,247
464
take care of the oil, take care of the filter elements, just the basic stuffs
turbolover
1,185
112
about air filters.i remember a few years back this guy with a silver top 4 throttle ask my mech about the power loss of his engine and when he opened up his hood,his open pod filter was so clogged up you cannot imagine.haha.either he drove in dirt road or his previous mech was an idiot.
leonl
229
81
USA
Use good synthetic oil.
Change oil more frequently.
Use higher octane gasoline.
Thicker head gasket to lower compression a little (4age engines usually are high compression).
Also, turbo timer to cool the off the turbo and to have oil properly drained out of turbo.
Good luck.
zendengoh
155
KL Kepong
www.zhapalang.com.my
and the cooling system as well.:proud:
EvolutionZ
5,000 RPM
5,027
1,448
melanz,
u fit it in what car?
pathfinder
231
the basic 1 is using good quality engine oil. It's fine to use semi-synthetic, just make sure dont exceed 5000km. If u regularly high revving/high speed, this requires shorter oil change interval.
also make sure cooling system is tip top. (oil & water flow). Drain & refill water/coolant regualrly (i darin & refill coolant every 10,000km)
dont overboost
turbo timer is helpful if u dont have time to wait at least 30 seconds (for normal drive). I dont have timer because i have the time to wait
dlj9788
40
Basicly, The Engine Oil Is The First Thing u need to see, what grade u using ? hv u upgrade anything to ur engine beside turbo ? hv u change the piston ? hi or low compression ? dun boost too high if ur piston compression is hi, exp (13.1 > up) hv u change ur ecu cause original ecu will hv the limit and will lock the fuel when reach the limit. add fuel regulator . must hv oil press and oil temp meter with u. that`s my opinion, but the main thing is ur engine oil, becareful not to rev high and remember to change oil whenever its dirty already. scare the conrod bearing will damage.
dawg
145
47
3,028
Selangor
dawgsevo.blogspot.com
make sure u install an oil temp and oil pressure gauge...
i prefer to cooldown my engine base on looking at my oil temp gauge compared to using a turbotimer to wait 30sec-1min just to cooldown... with the oil temp, u know how hot the oil is. normal driving should be 85-95deg for oil temp. if between 110-120deg ease off and cooldown the oil..
after hard runs, and ure engine oil is say 120deg... the turbotimer running for 2 mins also will not cooldown the oil to 95deg. u need to drive slow and let the air run thru your oil coolers etc to allow cooldown of the oil back to operating temps...
First there were 30 female participants who entered into this competition on the 24th of April 2012 at Tropicana City Mall; and until last weekend, there were only 12 left who had their focus locked and loaded to have the chance to represent Malaysia as one of the GT Queens for the 2013 Super GT Race season in Japan. Alas, the weekend has come and gone and so has their...
