To take care of turbo engine
LuKa
618
19
Kedah
Whats important is.. the engine oil n water... in order to do so.. you need something to monitor them b4 its already too late... if you add a turbo from which ur car did not hav any... it is advisable to install a few gauges 1st...
leonl
229
81
USA
how about running the car while the engine still cold?
Think about engine like your body. How do you feel to go jogging the second you woke up in the morning?
iczmage
9
I've heard that it's advisable to clean out the turbo. What does that actually mean? Is it cleaning the filter or the turbine itself? And also what is the optimum time to set for a turbo timer?
leonl
229
81
USA
I don't think you can clean the turbo itself. Unless you are taking it off to be rebuilt. As long as turbo is in good condition, no smoke, no shaft play, no oil sip, no winding noise, you should be good. Just make sure change engine oil frequently, because the engine oil in the engine is what going through the turbo to lubricate the ball-bearing/journal.
Definitely need to keep the air filter clean. Imagine breathing through a dirty respirator versus a clean one. Same concept.
The turbo timer today has built in features that calculate your driving time and load, then it set the turbo timer base on that conditions. Other wise, 5-10 minutes for "normal" driving, more for track or "hard" driving. Basically the longer the better.
I do believe if you take good care of the engine or turbo,you will get what you deserved in return. Just like your body :)
LittleWhiteWagon
1,656
187
P.J
Guys, for turbo cars is it better to run a slightly thicker or thinner oil? I dont have a turbo car, just asking for fun haha :biggrin:
LittleWhiteWagon
1,656
187
P.J
Haha nolah dude, im going for N/A at the moment :)
Waiting for $$ to buy DCOE Webers... :evil:
BLANk
1,750
6,757
Sardine
www.zerotohundred.com
LittleWhiteWagon:
better get the intake manifold for the side-draft carbie 1st lar...after that weber...^^
---------- Post added at 08:25 PM ---------- 6 hour anti-bump limit - Previous post was at 07:50 PM ----------
this one...hehe
LittleWhiteWagon
1,656
187
P.J
LittleWhiteWagon:
this one...hehe
Waaaah, is that for my GA16 engine? :biggrin:
Bugger christmas coming up and you want me to spend more money on the car again, hahaha. Yeah, i've been thinking bout a custom manifold...
alphangadan
25
6
1,503
Kuching
I have recently rebuilt my turbo. At the mean time I'm using a CA18DET turbo for my 4AGZE. Is it ok to use it directly like drag without the power intake? I'm driving it daily. Also can I wash my Apexi Power Filter with water.
Kenny Heiser 3, he does alot of work with carbon fibre, his shop even replaced all the panels on a porsche GT3 with new carbon fibre ones.
Here is an example of the same thing done on a 996GT3R Porsche . This was done where I work at for a client . Every part made for the car is Dry Carbon Fiber with Carbon-Kevlar . Basically a mold was pulled from every single panel of this car including dash , under tray...
