- Aug 14, 2007
- 975
- 14
- 1,518
if got that block i earlly buy already....if really got 3L block everyone put d la..
too bad its just a romour la..:sleep:
Where your proof that you've got the 4D3 liter block in AU? I've been around quite a while to know better. Unless you have proof that you have run that engine on such boost,I'll consider you just another scam!in sydney i got galant engine 4 piston 3.0 liter.Many ppl here put twin cam head and run 45psi boost with E85.
Bump: 4G64 block 6 bolt in sydney plenty..brapa banyak mau.RB30 engine lots la bro here.4D Diesel block 3liter already run 60psi with methanol.
you are not toni rigoliwhere your proof that you've got the 4d3 liter block in au? I've been around quite a while to know better. Unless you have proof that you have run that engine on such boost,i'll consider you just another scam!
R_RocketI agree with you . hopefully some ppl will not take me too personaly , I only wanted facts...not fantasy...,if the facts are there...please prove it...simple...
Ok sure,but personally? what about the rest? can I bring with me all the others who are interested for the block?? masqulinB8,kroolada,joe1,r_monsta,vteckiller...and the rest can or not??R_Rocket
If u want to know the 3L block come to my wshop at subang i can tell u how to get the engine.Personally come and see me.
Pehh mamat ni hot ni!...toni li goh li bai...hehehe...tu la 3rdgear banyak sangat hot topic you bikin.Where your proof that you've got the 4D3 liter block in AU? I've been around quite a while to know better. Unless you have proof that you have run that engine on such boost,I'll consider you just another scam!
Hi R_RocketOk sure,but personally? what about the rest? can I bring with me all the others who are interested for the block?? masqulinB8,kroolada,joe1,r_monsta,vteckiller...and the rest can or not??
---------- Post added at 01:43 AM ---------- Previous post was at 01:28 AM ----------
yes u can do thatsome question,
1. Can I just put forged connecting rod like scat or eagle but use evo standard piston? My aim 300-400hp only. As I know the weakest link in 7 bolt is the rod. Not enough money to buy forged piston
2. or better, just buy vr4 block, but very difficult to find this day
3. If change to forged short block (conrod & piston) is it compulsory to use ARP head & main stud plus race main & conrod bearings?
TQ in advanced
yesss finally someone post very useful question and answer...tq for both Q&A....no need to gaduh2 and kacau2 other forumeryes u can do that
u can also opt for cheaper solution, machine the vr4 conrod to fit ur evo crank , cheapest
remeber that scat/eagle uses floating piston pin
yes u can do that
thank jin..
what do you mean floating piston pin? mean I have to modify my standard evo piston to fit eagle/scat conrod? or have to buy the pin separately? do you think this mod can hold 400hp?
do I need ARP head stud & main stud and also acl RACE main&conrod bearing for this mod
thank jin..
pin use back piston can use back u can install them but need to modify piston a bit to put in the piston pin lock.
ARP head stud is gud upgrade and insurance when ur aiming for 400hp . Put in Metal head gasket while ur at it. Race bearing n conrod bearing dun need but a gud upgrade also. Better find OEM original mitsu bearing but gud luck finding them in malaysia hehe.
---------- Post added at 11:42 AM ---------- Previous post was at 11:35 AM ----------
example of fixed piston pin,semi floating and full floating
http://www.tpub.com/content/engine/14037/css/14037_104.htm
yes u can do that
thank jin..
do I need ARP head stud & main stud and also acl RACE main&conrod bearing for this mod[/QUO
