V-tec Vs Mivec
DaDoctor
422
I tried my b16A before with a 1.6 mivec belonging 2 a friend of my friend...
My car is EG3 and his car was satria...
In terms of 0-400m, he cannot tapaw me...
But the mivec has a very good top speed...
both cars in stock standard form...:biggrin:
Bump: I tried my b16A before with a 1.6 mivec belonging 2 a friend of my friend...
boyzone
2,669
38
5,148
Gear ratio make a thing different.
If both of the engine come with std gear ratio, u will see the different result.:smokin:
JackWaiKit
262
5
www.friendster.com
Some ppl said even B16A vs B16A from jp h/c..
there is some variation in between...hp loss....
Ok if i assume there is no any distrub...
Normally most of the ppl said Mit's will in better top speed...
I think B16B or 18C gearbox will be a bit difference rig?:confused:
afariq
371
38
In stock, i'd say the vtec will be infront. Even with mods (both cars), the vtec will still be ahead. I've got 1st hand experience:rofl: I drive a 4g93 mivec:driver:
DaDoctor
422
You're rite, both cars with std gear ratio...
But both cars have simple mods such exhaust system and open pod air filter....:rolleyes:
Bump:
Bump:
Bump:
JackWaiKit
262
5
www.friendster.com
Well guys...
Let's talk bout the maintenance...
My ride still occuring white smoke & top up 2 week once bout 500ml of engine...
I have change valve seal & gasket...stil the same...
My experience is when there is no white smoke, u have to decresae the fuel...
By the time, engine lighter...but after certain time...metal gasket spoiled...
GSR06
455
17
just my feel, I will bet my last dollar on the VTEC..... this is based on my friends' experience on VTEC...
MatLia
66
VTEC more aftermarket parts around the globe compare to MIVEC. So more room to upgrade. Anyway i do love MIVEC.
boyzone
2,669
38
5,148
a very good set up, very linear torque curve.:love:
Hicam kick in at 4500rpm.
hello again frens...got a problem here hope any1 can help advice or troubleshoot dis problem..went to a few mechanics already stil x rectified..:adore:
there is a vibration whenever a left turn is made (x prob when turning right)..or when moving from standstill eg traffic lite....anyone of d workshop i went to said its d drive shaft problem..at 1st i thought d same..all d cv joints were replaced..now here is d issue....
it still vibrates..to...
