Upgrade turbo.
wannaz
319
selangor
Hi semua,,
Need some help..
1. Can anyone tell me how much it cost to upgrade turbo TD05H(evo2) to TD05H/20g.?? and where ..???(klang valley)
2. Evo2 turbo..single fin or twin fin..???
regards...wan
jinkl
4,624
376
3,183
Hi semua,,
Need some help..
regards...wan
could cost u around 1.5k to make it to a 20g + td06 turbine wheel
evo 2 turbo is a twin fin
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
yes and no..
both turbine volute is 7cm2, BUT, evo-3 is lighter due to some weight saving methods.
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
some ppl would use a Garrett comp wheel with similar dimensions to a 20G (original Mitsubishi)... so for 1k... you'd only get a Garrett wheel.. if you're lucky you might find a second hand 20G wheel outside...
wannaz
319
selangor
thks again sum,,hope i will fine one...
jinkl
4,624
376
3,183
td05 20g was said to be not so nice in dsmtuners forum
maybe the 05h turbine wheel is a restriction & more back pressure
20g + td06sl turbine wheel seem to be a nice combo
but then again, original MHI compressor wheel + turbine wheel doesnt come cheap :)
gurantee to make u faint after hearing the price hehehe
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
the stock TD05 turbine wheel needs to be "clipped" or "cut back" to allow it to flow better once mated with the 20G or a Garrett wheel..or else..it'll start choking out.
why DSM fella's prefer the TD06 turbine wheel..mainly due to size and if you go for the Td06L2 (newer design) , less number of blades and spread out further, hence you don't need to cutback these turbine wheels.
Bump: the stock TD05 turbine wheel needs to be "clipped" or "cut back" to allow it to flow better once mated with the 20G or a Garrett wheel..or else..it'll start choking out.
jinkl
4,624
376
3,183
true :)
td06sl fits the vr4/evo1-3 turbine housing
the td06h doesnt fit the evo3 turbine housing , housing too thin no meat to port hehehehe
td06sl comes pre clipped
The Marketplace Top Posts
My original headlight HID control panel always gives problem simply because its located on the bumper which is at the lower part of the car...
Each time we speed through the rain water ponds, and when the water goes into the HID control panel, the headlight will sometime work and sometimes dont work...
Some of my frens with similar cars already converted to the ones recommended by the accessories shops.
Its of course cheaper than the ori.
Now my question is....
Is it ok to do...
