Turbo Charging Kenari.
blue_hippo
978
wah this topic keep coming and coming.dude ...try searching in the forum..there are many thread of the stated topic....try finding
Kelisa R - MJz
366
^_^
Turbo charging Kenari? Why need to do that?
blue_hippo
978
got so much $$$ kua...hahha
ccibai
59
msia
if juz pasang turbo aje + small intercooler the most is 6-7 psi. More than tat--- tak cukup minyak. need more boost = more fuel n lower compression.
Xenix
3,330
Kuala Lumpur, P
honda_fans.tripod.com
HCOC - http://hcoc.net.my
Not enough fuel = got haltech.. maybe add extra injetor lo.
any suggestion what turbo kit to buy? bolt on kit?
ccibai
59
msia
ahah ok ok if u r goin haltech way 1 then no worries. Buy haltech E6X. Turbo ah, my fren kelisa is using IHI RHB 5 lah, if high boost then use front mount IC. Heavy duty clutch, lower compression using gasket n grind some part of the top of the piston. n also i think need bigger fuel pump n fuel regulator. Brake system also need to upgrade coz original cannot stop . Got 1 kelisa i know using E6X running 1.5 to 2 bar go ard 150 hp at wheel.
K-Kid
1,270
Earth
Yes yes, turbo charge it. What are you waiting for? 150hp on wheel can go sepang drag adi...
Kelisa R - MJz
366
^_^
Ha ha ha! Can tapao me also...
E6X... RM5000++ la! Think clear a bit la!
K-Kid
1,270
Earth
Ppl's father loaded, want add 150hp to his wheel...5k not so expensive for them la. :D
ccibai
59
msia
tat guy who own the kelisa really spent a lot of $$ on it.( He also got a fully modded supra running NOS. ) But me n my fren not loaded so hv to go for cheaper alternative using Sub-injectors controller n can only get 110 hp.
K-kid n Kelisa-R = i m not trying to show off or wat but it is true. Dun say E6X Rm5000+ tat car even juz to get the right tune on dyno also dunno rebuild how many time engines liao.
Bout the sepang racing, the car is located in sabah 1.
as title.. my car start to jerk after the service... i found out tat the mechanic do overfill some engine oil... white smoke.. smell bad n car jerking.. izit the effect due to engine oil overfill?
