Strong fuel smell....
Giant Dan
43
Do anyone experience strong fuel smell in the car while driving ..? The smell do not come frequent but occasionally. I believe something is wrong.. but i have sent my car for inspection at several mechanic and they do not detect any problem. Any sifu please comment.. Thanks
:hmmmm:
Cheongxp
94
508
Selangor
This only happen in full tank condition & when driving uphill ?
I experience this condition, but this is come from fuel tank cover ( actual name i didn't know ) open but didn't know why it open & this is at rear side seat near to fuel tank area.
Giant Dan
43
Bro cheong.. you mean the fuel cap.??? the place where we pump the petrol.?? or how do we access to the rear side seat..?? open up the seat..?? please comment. Thanks
Cheongxp
94
508
Selangor
Don't think is Fuel Cap, What i heard from my mechanic, need to dismantle the rear seat. Heard is rubber cup.
Giant Dan
43
cheong.. mind to share which mechanic that you send for the repair.. appreciate if you could let me have the contact and place. I had tried several mechanic also cant solve th fuel smell problem..
doraemon98
202
6
It could be the fuel tank under rear seat bocor, or the cover that cover the float on top of the fuel tank problem.
12savefuel
195
75
I also has a fuel smell problem on my A32 3.0L. I only noticed it after I fill the car up full. After some time when the level drops the smell no longer there. I also notice fuel dripped on the floor after I parked the car when the tank is full, no problem when the fuel level dropped.
So I check out all the hoses and they were ok. So I removed the rear seat opened up the metal cover covering the fuel hoses and pump + fuel sensor wiring. Had the car with full tank of gas and guess what I found that there was small hair line crack on the top of the fuel gauge sensor. This is the one where the fuel pump and gauge wiring couples to and the fuel supply and fuel return hoses enter the tank. The whole assembly is made of plastic and there was a very small crack. Fuel was coming out of the crack and filled up the whole top of the assembly. Had the car running and could see bubbles coming out from the crack. So when the tank was full to the brim the fuel was coming out from there and the internal pressure also pushes the fuel out. So when the fuel level drops. No more problem as the leak is from the top. So I dried it up and super glued the crack and so far so good. No more smell and no more leak.
doraemon98
202
6
Hairline crack ah? Just as I thought the rubber seal could be the culprit also.
I doubt Super glue could last. You can use epoxy next time it holds better.
12savefuel
195
75
My rubber seal was ok, the crack was near the socket for the fuel pump. I decided to use superglue first as its thinner and is able to flow into the crack properly. Will epoxy on top of the superglue if needs be next time. I also did a few layers of superglue so should be ok. Its got no load or anything on the crack so superglue should be more than enough.
dee889
22
Find mine have similar problem. Hv to find time to do the same...huhu
dee889
22
car got accident history?
I just owned the car recently and the symptom it just similar as what bro 12savefuel mentioned. Visual inspection does not indicate the car had any major accident. Anyway as mentioned, will spare some time to check underneath the rear seat as suggested.
doraemon98
202
6
Just use epoxy to cover back the cracks can ad.
option1978
213
83
Any possibility that fuel hose joints leaking? Had the experience but with my proton twice, once the supply hose & another time the return hose.
Dear Friends,
We all love our cars & like to improve our rides (if u're not, u won't come to ZTH, right?) :biggrin:
I would like to know how do u measure improvement of torque & hp without putting ur car to a dyno machine..?
Especially after u bolt on some simple performance part..
Let me share how i do it 1st.. i'm not a pro.. so, my method is not exactly correct..
IDLE SPEED
the 1st thing i would do is take note what rpm my engine idle before and after i bolt on the...
