SR16 NEO VVL & NEO VVL N1
Dbass
156
Ampang, Selango
I just want to know, is it very hard to find spareparts for SR16NEO VVL for nowaday in KL?
Example...waterpump, conrod bearing, throtle body,piston, maf/map sensor, valve etc....
Cause, I think in future want to use SR16Neo VVL in my Sunny B11.
Anybody can help me give the opinion.....
thanks......
mant53
13
1,503
u can ask atai.. he BOT his sr16ve... can mengular when turbo kick in
monsh
157
18
518
i think for nissan engine sr20 easier to source out items .
try see at nissan marketplace see if u can find parts if sr16
cmng
3,289
72
Part in term of what aftermarket part or OEM
FYI
SR16VE sharing a lot of part with SR20DE and as well SR20DET
only certain item is isolated like it own part like main pulley, distributor etc,
The only issue is aftermarket part which is limited.
and to search aftermarket part for SR16VE, your result will be limited
but if you search SR20VE, it will be more result
if you not intent to build up crazy hp or just intent to mini minor mod
SR16VE is still affordable to play around
Dbass
156
Ampang, Selango
Cmng,
I want to use for normal driving, to send my children to school.
Therefore I need only OEM parts only.
Is it very hard to find OEM parts like distributor, maf sensor, throtle body, VVL solenoid,
timing belt bearing, water pump. Can I easily buy from sparepart shop?
One more thing Cmng,
I want to use Sr16Neo inside Sunny B11.
How many mod need to do for this convert my Sunny.
Example, engine mounting need to modify.
How about crossmember, driveshaft left/right and knuckle also to modify?
Is it dashboard also need to trim or cut to fit inside sunny.
tq very much Cmng and others for info and helping me......
djlee
Hey guys, all this excitement about honda's and Neo's........good atmosphere. I own a B11 and just did a swap with a SR20 Neo VVL. Half cut was cheap ( bought it on my own), workmanship to install cost 1.8K.Paint,body work and accessories came up to 5.5K. Problem here was it was a very bad job. The car is not performing as it should, the foreman was really a shit-head cheat and we got into a fight because he was cheating me left right and center. well after all of that I'm stuck with trying to repair his shit work. What ever it is..do not get your cars to be worked on by this jackass at Speedline Puchong....total rip off artist,big time liars. Very irresponsible.....need help in repairing my car and doing it right.....any offers out there????
djlee
Thank you bro,but where are they located??? any phone number?
Truly appreciate your kind asisstance.:biggrin::biggrin::biggrin:
Get Dimensions
Width = 9.2
Height = 4.8
Switch
height - 1.9
width - 1.4
Get Materials.
Preferably Aluminium Sheet 0.7 mm or less. . Plexiglass might crack while cutting(Unless you have sum advanced Laser cutting machine.:p) If you're from Seremban, You can get this from Tukang besi..corner shop same row with Dunlop Tyre Shop in Temiang.. Right in front of the Traffic Light
Switches
Prepare...
