Are you a street driver or track warrior searching for something to quench your "THIRST FOR SPEED"? Let MEGAMANICS WORKSHOP build your dream and we’ll surpass your expectations.
MEGAMANICS WORKSHOP has just the right upgrades for any “Street Drivers or Track Warriors.” . Our workshop offers a range of services from servicing & repairs to complete engine rebuilds, drive-line upgrades, suspension upgrades, performance enhancements, modifications and many more for all Road, Performance Street, Drag & Race car applications.
Snow Performance Water Methanol Injection System
Snow Performance Water Methanol Injection System:
-150+ PSI High Volume Pump
-3 Quart Reservoir
-Digital Variable Controller (Stage 2/3)
-2 Nozzles To Cover a Wide Range of Horsepower
-All Required Hardware Needed For Installation
For Turbo,
This kit uses manifold boost pressure to determine when and how much fluid to inject.
Proportionally injecting according to boost pressure gives the most accurate delivery of water-methanol and allows the most cooling and performance improvement over the widest range. More power and drive-ability is the result.
It can be used on any forced induction engine: carburetor, fuel injected, turbocharged, positive displacement or centrifugal blowers.
The most suitable are the centrifugal supercharged and turbocharged engines, as they build boost is a more progressive manner concerning water-methanol injection. The positive displacement blower engines will work, but it might take more work to dial in the delivery.
For N/A,
This kit uses a progressive controller that proportionally injects more or less according to manifold vacuum. Start and full points are adjustable for engagement and delivery curve, to match what the engine requires. High compression modified engines can gain performance through cooler intake charges and the large increase in octane and detonation suppression. It can also be geared towards fuel economy and using lower grades of gasoline.
Ready stock. Lifetime warranty
Call for best pricing & special package offers.
Please contact Megamanics Workshop at 0127857113 / 0176527113.
For More information kindly visit us / find us on our Facebook (megamanicsworkshop). We are looking forward to serve you.
Thank You.
-3 Quart Reservoir
For Turbo,
For N/A,
Thank You.
