Item(s):
SNOW PERFORMANCE Stage 1 - Water/Methanol Injection for NA engines (any car)
Package includes:
Complete Stage 1 For NA
Extra 60cc nozzle will be given together with the set, thus u can have (100cc standard nozzle and extra60cc nozzle)
Complete Wiring already done by my wireman
Custom Made Bracket and holder for the Tank and the pump
Sensor and LED lights
BOX and user manual
Price:
ITEM BOOKED
can arrange for Installation (rm 200 - 350 depend on car)
Warranty:
Warranty Life time by Manufacture, Receipt will be given to you
Dealing method:
COD, Bank in, Pos Laju (bare by buyer)
Location of seller:
Jalan Klang Lama, Sunway, Bangsar, OUG area
Contact method/details:
Call 012 342 3596
Age of item:
2 Months old, Used for Demo Purpose Only
Item(s) conditions:
In Perfect Condition, No scratch or damage, all working properly, Box is kept well too, Perfect condition - Like New
Picture:
Complete Package photo from the main supplier as below:
Actual Photos of Item in box:
Reason for sale:
Used for Demo purpose on my wira, and now im selling off my beloved wira
Package includes:
BOX and user manual
Price:
ITEM BOOKED
Warranty:
Dealing method:
Location of seller:
Call 012 342 3596
Age of item:
Item(s) conditions:
Picture:
Reason for sale:
Boost Cooler Benefits:
1. Low cost - affordable solution with high results as you can get up to 60HP.
2. More power than other means of detonation control.
3. Efficiency - leaner air fuel ratio can be utilized for normal operation.
4. Greatly increases air charge densities for huge horsepower increases.
5. safety for your engine block and your pistons, as they are always cooled.
Methanol Boost Cooler for NA engines:
Naturally aspirated/stock compression:
With naturally aspirated engines with less than 10:1 compression, water/methanol is used typically in warm climates to get the intake temps back to 60f. Benefits include: 10-15 HP increases from air density increases and full timing, Increased gas mileage, and carbon free combustion chambers. Activation is by a throttle switch adjusted for onset engine load. With this application, the nozzle is sized so that no more than 10% of total fuel consumption at peak flywheel HP is injected.
Why Methanol?
Methanol is a high octane fuel that is extremely resistant to detonation with an excellent cost/benefit ratio. Its high latent heat of vaporization also makes it an excellent air charge cooler which means a denser mixture and more horsepower. Because of these facts, it is a better anti-detonant than ethanol or iso-propanol although they will work in a pinch. It has however only about 60% of the energy content of gasoline by volume so about twice as much is used to make similar power if used as a straight fuel.
Whom can use this Boost cooler?
Any car with Normal Engine (NA Engines) applicable to any car (Proton, Toyota, Honda, storm, hilux, BMW, Alfa, etc any other car with NA Engine)
if you like to explore more about Snow Performance - Boost cooler you can visit Snow Performance: Home
Why Methanol?
