AMS Alpha Carbon Fiber Performance Intake System A45 CLA45 GLA45
The OEM manufacturers spend a lot of time reducing turbo noise at the expense of horsepower. By letting the turbo ingest all the cold air it needs, the Alpha Mercedes-Benz A45 AMG Carbon Fiber Performance Intake System boosts power significantly. In addition, it allows you to hear the turbo spool up which is something you as an enthusiast can appreciate.
DESCRIPTION
Simple Upgrade, BIG Power Increase
Our engineering team immediately noticed a considerable level of restriction in the stock intake system and solved the problem by designing a smooth transition to a much larger filter. By upgrading the size of your 2.6″ factory inlet filter to a robust 4″ design, we drastically reduced the high pressure drop – a sure indicator that your stock intake filter is choking your 2.0L M133 turbocharged engine. By simply installing this air intake upgrade on its own, you’ll be rewarded with a 20+HP increase!
Smooth Design And Unobstructed Airflow
In an effort of cost savings by the manufacturer, your 2.0L M133 turbocharged engine comes equipped with a corrugated plastic air duct which disrupts airflow. To make matters worse it also features a big support “pillar” in the middle to keep the flimsy plastic from collapsing which hinders power output. With the Alpha Carbon Fiber Cold Air Intake Duct, we eliminated these restrictions – supplying your engine with all the air it needs!
Cool Air For Your Hungry Turbocharged Engine
Often, aftermarket intake systems feature an open filter element which actually reduces horsepower by drawing hot air from within the engine bay. This may net you some power on the dyno while the hood is open and cooler air is available, but decreases performance when the hood is shut. By taking full advantage of cool outside air provided by our sealed air box and inlet design, you reap the benefit of maximum power as you fly through the gears of your Speedshift DCT 7-speed transmission.
The Difference Is in the Details
We took the time to match the carbon fiber weave pattern and finish to match your A45 AMG engine cover. In addition the Alpha logo matches in color to the AMG logo and trim found under the hood giving you a super clean look that will be sure to impress your friends!
Built To Last The Life Of Your Car
CNC’d billet aluminum construction and an anodized coating ensure this piece will look and perform great for years to come. The smooth and strong mounting surface for the air filter ensures a tight seal. Couple that with a purpose built, synthetic high-flow dry media filter means you won’t have to buy those cheap factory paper filters down the road. Simply remove and blow off the filter with compressed air periodically or wash out and let it dry. No messy oils or special chemicals needed.
Serious Buyer Only.
postage can be arranged.
We ship worldwide
Alan 012-4038323
https://api.whatsapp.com/send?phone=60124038323
DESCRIPTION
Serious Buyer Only.
We ship worldwide
Alan 012-4038323
