Price very cheap compare to kl price.....look neat......
ermm... depend on luck too le....
Bump:
wah S15 turbo so cheap? KL here if you dont have 1500 u dun even think about it. Same as the pipping lo. S/steel piping with Samco hose (not to forget fasterner) defineitly cost more thn rm1k here. Soon u will find SAFC not "complete" enough. Thn upgrade to Emanage. Thn will need to change colder plug.
Fw thing i think cost didnt list out. Injector, fuelpump, BOV, Exhaust definietly need bigger unless previous already on 2.5", oil feed line...
by the way, im curious, you use GZE crank, rod and piston but u ditch the block? Why? I thought GZE ae1x1 version around 9.x:x but why said hi comp? Thn u mention sell gze map sensor then buy back another gze map sensor?
actually the turbine was brought from people want to upgrade thier turbo... so can get it a bit cheap lo...
S/Steel piping with samco hose really no forgot the fasterner... really... Every short L are about RM 10 only, long L are just RM 25 only... all is brought from s/steel shop, for building the gate and so on... so u think it very expensive? Just the formen charges are expensive... haha
Few thing i think cost didnt list out. Injector, fuelpump, BOV, Exhaust definietly need bigger unless previous already on 2.5", oil feed line... <-- true also... the oil braided, BOV, and fuelpump was miss out ...
exhaust should not calculate gua... it seem an optional thing... Anyway this is i roughly calculate out (base on what i know the price that he use on it)... and this is not my car le...
Oil braided = RM 100
BOV (imitation) = RM 150
Fuel pump (Skyline) = RM 120
Ditch is what mean? Anyway, u mean why don't want to use the block? It is because the 4AGZE block was no geran and custom form... mean not legal use
Why say hi comp, it is because in the 4AGZE are most hi com than the 4AGZE AFM model ma... Anyway didn't mean 4AGE high comp le...
Thn u mention sell gze map sensor then buy back another gze map sensor? because sell whole set with the ECU and wiring ma.. So got to search the map sensor only lor... then buy the map sensor from other user. Hope i was made it more clarify already.
Bump:
errr...still wonder where to get 4agze enjin lantai....if can get easily..sure conversion cost will be lower...as i knew..its so hard to find this stuff....like in this case..u r so lucky to get 4agze engine lantai at rm 1.6k...include all and still can sell unneeded part...
BTW good luck to u n the rest who wanna be turboed...heheheh
4AGZE no geran normally will sell cheaper... anyway also depend on luck too
