Product testing : Blue Chem fuel system clean
ixeo
4,788
3,080
KL, Malaysia
super fei lo
1,331
12
I hope not getting stuck at the fuel injectors. :rofl:
All the gum & varnishes is dissolved in the fueling system.
No worried that it will clog your injectors.
You will be impressed after the live demo..
Car club is welcome..
:beer:
ixeo
4,788
3,080
KL, Malaysia
:beer:
you mention its either contamination or water. fuel injectors are part of the fueling system.
water is not an issue since it will just be converted to steam in the combustion chamber and comes out from the exhaust. considering it mixes with the fuel I doubt it'll cause rust for the internals of the fuel injector.
if its contamination - something solid, how can it be dissolved? for example, silica.
nah. It completely emulsifies anyway.
---------- Post added at 09:38 PM ---------- 6 hour anti-bump limit - Previous post was at 09:36 PM ----------
I can only assume you're not talking about sand in the combustion engine but in the fuel tank. Debris like sand won't dissolve in petrol I think so it probably will clog your injectors eventually. However the fuel system is relatively closed, I'd be curious to know how on earth sand got in in the first place.
kaninbu
669
104
with the contamination fuel surely poor u get poor fc.this product will minus octane in fuel?mix with v-power perhaps?
ixeo
4,788
3,080
KL, Malaysia
How on earth? Well earth is composed of sand and dirt anyway.
http://www.i-car.com/pdf/advantage/online/2004/042604.pdf
http://www.carterfueldelivery.com/fuelpumps/_pdfs/support/TEC1622.pdf
its well documented, not rocket science :rolleyes:
super fei lo
1,331
12
Thanks Ixeo for the valuable information for all ZTH member.
You are totally right about the contaminations such as moisture in the fuel especially diesel because diesel originally contains moisture. Moisture act as food for micro organism. And they breed in the diesel. It causes blockage in the fuel system. The worst nightmare for Compress Ignite Turbo Charger Engines. Prevention is better than cure. :nurse:
:love:
In Malaysia, so far we didn't recorded any silica contaminations in our fuel system.
This silica contaminated fuel normally documented in places with lots of sands and winds like desert.
Mainly cause by mishandle during the shipping process. Fuel containers is exposed to winds and sands. So sands ended up in the fuel delivery tank, to your fuel station than to your petrol tank.
Countries that normally face this kind of contaminations is like Australia, Sahara and Arab.
Please correct me if I'm wrong.
---------- Post added at 07:16 PM ---------- 6 hour anti-bump limit - Previous post was at 07:12 PM ----------
Video about how it works in the fuel system
Powermaxx Fuel System Cleaning & Diesel System Cleaning (en) - YouTube
sori..if i posted at wrong section..im still newbie in car's engine part..so dun flame me lorh..my evo gearbox is giving me prob as the cluth shaft goyang..do this item sold separately from gearbox..or i need to buy new gearbox and i dunno if its called clutch shaft or centre shaft..
