Hi..
Surely not a sifu, but wanted to share...
a. for me, the best piston would be re-installing back mivec piston...surely compression will knock out high.. but can be manage by slotting in a thicker metal head gasket to reduce it and later installing piggybacks to eliminate knocking..
b. my afr setting oso is at 4 bar, thats the best setting for my car...more or less will make the engine 'lemau'...
c. Fuel pump...im using walbro...previously using a 4wd fuel pump...serves me ok...
d. injector..for 1.8 better use 275cc and aboved...if ur using back the 1.6 injector; afraid it will become 'lemau' at hi rpm...
btw...manage to install n set e-manage last month...result: a decent 155whp with 16.3 torque on dyno..maybe later will upload the dyno chart..
