Need Advice for Adjustable Cam Pulley (DOHC Engine)
szeeonn
131
10
for turbo
u have been using mat speed 272/272 ?
how's the timing issue ?
only worried timing issue lol
D7zul
2,697
848
Shah Alam
Back to the adjustable cam pulley ..
the purpose of it is to adjust the timing to increase power at certain RPM.. not all the way from 1k - 10k..
eg.
15degree advance to increase power at 1k - 5k..
0 degree to increase power at 5k - 10k..
it also depends on what engine u use.. not all engine respond to the setting the same way.. because of their design..
and also if u use big cams such as 272/260, u must rev very high to achieve the desired horsepower.. NA tuned..
for turbo usually they use bigger turbo.. or twinturbo..
i suggest find a good tuner for ur engine & learn from them..
Gudluck :burnout:
For Toyota 4AGE engine read this
http://www.billzilla.org/4agmods.htm
Veloc
3,234
991
Sabah
eg.
Gudluck :burnout:
Bill Sherwood's Modified 4AGE Page
Haha... That page is my early source of knowledge too... Still very useful! :burnout:
93na
597
20
i agree to that.. a good tuner is the answer.. he be able to advice you on to do.......
szeeonn
131
10
hmm guys ..
which cam suitable for my turbo
270/260 or 272/272
tq
D7zul
2,697
848
Shah Alam
hmm guys ..
270/260 or 272/272
tq
Mayb u can list down what u've done with ur engine so far..
1. What engine?
2. Stock turbo or aftermarket one?
3. How much boost?
4. Exhaust header & pipe?
5. Air filter?
because tuning an engine is about balance.. not like add this = add power.. sumtimes we add sumthing, the power goes down..
:driver:
szeeonn
131
10
1. What engine?
3. How much boost?
5. Air filter?
:driver:
4G93 Turbo , E3 turbo , Want to boost 1.3 , exhaust Banana pipe 2.5 inch bend (2wd tank)
air filter ? got kena mengena ? i dunno lol .. i din install air filter yet .
tq
D7zul
2,697
848
Shah Alam
tq
max cam size u can go with aircond is 270/260 duration, 10.00mm Lift..
and u might need an aftermarket ECU to tune it well..
air filter restrict air intake.. so, u'll loose power if u use the standard one..
Gudluck :burnout:
szeeonn
131
10
nice info bro ..
bro if i put in 270/270 .. would effect car engine timing?
the timing will up down up down ..?
or how ?
coz if power concern, 270/270 more power right ?
i am going to Emanage after put in hi cam
D7zul
2,697
848
Shah Alam
nice info bro ..
or how ?
yes, it will effect ur timing..
better go for 270/260
szeeonn
131
10
haiz . i also pening2
ppl say exhaust ?MUST LARGER becoz need more exhaust gas spool the Turbo
so now i am very confused ..
szeeonn
131
10
u order online ?
from australia ?
how much it takes you ?
xtremeleo
3,247
464
5,183
i adjusted my pulleys and was able to produce up to 90lbft on a std 4g91, two set of mountings were damaged/broken on the first day. i had to leverage out the torque curve across the revv range or i am risking yet another set of engine mounts, lol. now using full rubber racing mounts, but wit top end setting, for dat peace of mind
so, no big difference? i dont think so..
D7zul
2,697
848
Shah Alam
u order online ?
from australia ?
no la.. i dont own a 4G93 Turbo..
what i meant was my reference come from that website..
u can find the same cam at Sunway, etc.. and i think it's cheaper..
Gudluck :burnout:
recently i bought a water temp gauge but havent fit into my car...
is this gauge installation just tap from wire or i have to buy other stuff like sensor or things like that?
soli la...
i'm dummy...
anyway, thx for the info..
