272 should be maximum for stock engine if not you will not have enough vacuum in idling, also your engine will stall at low rpm unless you willing to go for above 1k at idling. My opinion get 264/272 for response cam.
Get Materials.
Preferably Aluminium Sheet 0.7 mm or less. . Plexiglass might crack while cutting(Unless you have sum advanced Laser cutting machine.:p) If you're from Seremban, You can get this from Tukang besi..corner shop same row with Dunlop Tyre Shop in Temiang.. Right in front of the Traffic Light
Switches
Prepare...
