aja said:jester,
When the time come, let us eat 'sup gear-box' (gearbox soup)!!!
can! can!
as long as it's not sup torpedo sudah la
aja said:jester,
Sato said:i was worried too last time when i got the car...then thought of getting gearbox oil cooler.....mocal make......but then....even several rows of oil cooler costs a bomb....then...i went like " what the heck...juz drive...." Until now.....still ok woo..hahaha
Iwas told that if wanna add oil cooler for gearbox.....u got to think if it does help the gearbox !? Run too cold will damage the gearbox too...
jester said:just do regular flush of the gb bro
aja said:Better change to manual la, try to mod gearbox from H22A. Donno can fit or not.
Actually, for Japanese make, the most tahan gearbox is Toyota/Daihatsu. Other makes like Honda, Mitsubishi, Nissan, Subaru etc or even BMW auto gearbox not soo durable. For instant, my Charade Detomaso, currently milleage clocked around 120k++ km..the auto gearbox still intact!. Still can speed up to 180kmh!!
jester said:actually i saw 1 h23a dohc vtec engine in one chopshop in subang 2 months ago. sure monstrous torque punye
amdfaisal said:I thot H23 DOHC non VTEC only.
aja said:F20B 5 speed manual really hard to get, unless u try to mod CD6 H22A manual gearbox into it. Donno can muat or not!!
Sato said:H23A is accord CF6 engine rite ? Wagon that comes with performance engine...if not mistaken !
Sure got dohc Vtec ~
lidistick said:The H22A gearbox will fit. the only issue is that I lose the LSD on the SIR-T. and the ratios on the SIR-T are closer and more aggressive than the CD6 H22A.
the next gearbox to look for is actually the CL1 Euro R with fantastic ratios and a very good LSD. Again. So rare. :(
aja said:Euro R manual gearbox is damn hard to find & pricey (carrying code T2W4) and the stock ratio actually not that fantastic la. FYI, the ratio for this year 2000 2.2cc CL1 is moreless the ratio for 1997 1.6cc Mitsubishi Lancer Mivec only (Second Gen Mivec..CK4A). The only different is the 5th gear, whereby at stock standard CL1 5th gear could drag to the speed of 259kmh @7800rpm, as stated by Honda. 5th gear for Mivec CK4A/CJ4A would last around 237kmh @ 73++ rpm. FYI also, 5th gear CL1 speed around 236kmh, rpm stood around 73++ rpm also. Standard readline for CL1 is 78++rpm (sometime 80++rpm) and for Mivec CK is 83++rpm.
So, for me..driving CL1 don't gave much different from driving my previous old Lancer CK!.
Sometimes i wonder why this happened, cause comparing Honda 2.2cc with Mitsubishi 1.6cc ...by right this 2.2cc should gave us more!!
H22A CD6 manual originally don't have LSD. If u want to use it, so have to buy after market one. Apprently for non Type R engine, only non-helical LSD are available. FYI, only Honda Type R engine comes with Helical LSD. So, it won't give too much power constrains to your wheel.
As for the gear ratio, that one can always adjust one. no need to worry!!.
jester said:alternatively, just tarbo charge it la
jester said:aja, what's the color of your car? white? or red?
aja said:It's CH9 with DOHC Vtec blue cover engine inside. FYI, the meter panel also nice. If i'm not mistaken it comes with white color + italic numberings.
It comes with 5 lugs wheel bearings, same as Euro R.
amdfaisal said:eh aja... i'm planning to convert to 5 lugs after this (tukar cermin, cat kete dll). ngam or not if i install this CH9 py axle. cheaper than euro R or more expensive??
amdfaisal said:jester,
just want to know where this shop la. maybe want to take a look at the axle... 5 lugs :)
Similar threads | |
