toyoae111 said:can anyone here tell me is it worth to use microtech in a BT 20v? anyone tested? :X-:
noob here....
toyoae111 said:thx bro scomatic....i got to try to pm EG9... :regular_smile: BTW... if compare wit other ECU like TRD, TOM etc etc.... which 1 can give more performance? mircotech or others ECU? how much is a TOM's ECU for BT? i oni know mircotech will cost cost rm4300 (Mircotech LT-10s) including tuning for BT....
bro EG9 plz help!! which 1 better??? :X-: noob here....
scomatic said:Microtech la.. bro... Everything can be customize...
The TRD, TOM's, Blitz, and Buddy Club aftermarket ECU faced 1 problem is at the ECU can make the customized lor... and cannot compatible (cannot push the MAX Power) with the High CAM
toyoae111 said:NA setup... wat ECU do u recommand? im thinking to swap another ECU that can give more performance if microtech is not recommanded... :regular_smile:
additional info, TRD ECU is very hard to get, Toms, Imec and Mines still possible but hard to get as well for blacktop 20V.cuscostrutbrace said:Not much effect on N/a engine,try source for performance ecu such as TRD,Toms,Imec,MInes etc
TRD, TOMs, Mines, Imec is all rechip ECU which still maintain the original ECU PCB board. Normally they produce the ECU to according to the spec that you request. Above ECU only available in used unit. (Kedai Potong or used peformance part seller).toyoae111 said:thx bro scomatic....i got to try to pm EG9... :regular_smile: BTW... if compare wit other ECU like TRD, TOM etc etc.... which 1 can give more performance? mircotech or others ECU? how much is a TOM's ECU for BT? i oni know mircotech will cost cost rm4300 (Mircotech LT-10s) including tuning for BT....
EG9 said:TRD, TOMs, Mines, Imec is all rechip ECU which still maintain the original ECU PCB board. Normally they produce the ECU to according to the spec that you request. Above ECU only available in used unit. (Kedai Potong or used peformance part seller).
Normally you won't know the exact spec that the ECU set for. So there is no the BEST ecu to suite your car from the above ECU except you can get the ECU that tune to N1 Racing spec in Japan.
The best ECU is the ECU that able to tune to maximize your engine spec output which normally standalone ECU able to do that. Good tuner is a must for this standalone ECU.
Best ECU = Standalone ECU + Great Tuner.
scomatic said:An impressive answer! haha.. As I said EG9 are an veteran experiance on the ECU part.
