Ignition system for GTti... need help!!
everblur
222
The problem is I bought the GTti engine with ECU only. So considered as engine lantai. Now engine is mounted... everything else fixed except car cannot start cos no ignition wiring. Based on your experience, what parts are required to get the car started and moving?
Correct me if I'm wrong:
- ignition coil
- igniter
- distributor
- map sensor
Anything else?
kevinkeow
116
hei... You change to GTTI already? so how are you lately? seem you having problem with it.. why get engine kosong? with ecu only? Wiring? everything not complete? well actually just to said hi. I got no experience with it. Any update about your car?
everblur
222
Hi bro, do you know anyone who can help? Maybe if they look at it they would know better... I wouldn't mind paying as long as they can help... cheers
Hi sifus,
Need some advice here.
Few months back, my car a Proton Wira 1.6 has encountered swaying problem.
At times the steering would pull to the left and at times will be to the right even on a straight flat road (Kesas, NPE or Federal highway).
Even on straight road the steering always has to be corrected.
I've changed rims, 4pcs brand new tyres (PS3), all rear bushing (including trailing arm is brand new), alignment but things became worse!
Front lower arm (driver's side)...
