Ignition system for GTti... need help!!
everblur
222
The problem is I bought the GTti engine with ECU only. So considered as engine lantai. Now engine is mounted... everything else fixed except car cannot start cos no ignition wiring. Based on your experience, what parts are required to get the car started and moving?
Correct me if I'm wrong:
- ignition coil
- igniter
- distributor
- map sensor
Anything else?
kevinkeow
116
hei... You change to GTTI already? so how are you lately? seem you having problem with it.. why get engine kosong? with ecu only? Wiring? everything not complete? well actually just to said hi. I got no experience with it. Any update about your car?
everblur
222
Hi bro, do you know anyone who can help? Maybe if they look at it they would know better... I wouldn't mind paying as long as they can help... cheers
Hi there,
Lately a friend of mine teaches me how to clean those hard to reach and hard to clean dirt on your engine block using a cheap and effective way -- Carburetor Cleaner
ATTENTION BEFORE START USING -- this Carburetor Cleaner (CC) is corrosive to plastic, paint and your hand, so cover things that should be covered and wear a gardening glove. Wash your hand with clear water to avoid itchiness.
Just put a cloth surrounding the area of dirt, spray the...
